Table of Content
Honda CRV Shop Manual 00-1
SUPPLEMENTAL RESTRAINT SYSTEM (SRS)
Introduction
How to Use This Manual
Safety Messages
A Few Words About Safety
Service Information
FOR YOUR CUSTOMER'S SAFETY
FOR YOUR SAFETY
IMPORTANT SAFETY PRECAUTIONS
Table Of Contents
Index
General Information 01-1
Chassis and Engine Numbers
Vehicle Identification Number
Engine Number
Transmission Number
Identification Number Locations
Warning/Caution Label Locations
Lift and Support Points
Frame Hoist
Safety Stands
Floor Jack
Towing
Service Precautions
4WD model Information
Precautions on using free rollers:
Speedometer Testing Procedures
General
Service Precautions (cont'd)
Electrical Troubleshooting Information
Five-step Troubleshooting
Wire Color Codes
Abbreviations
Specifications 02-1
Standards and Service Limits
Engine Electrical
Engine Assembly
Cylinder Head
Engine Block
Engine Lubrication
Cooling
Fuel and Emissions
Clutch
Manual Transmission and M/T Differential
Automatic Transmission and A/T Differential
Rear Differential
Steering
Suspension
Brakes
Air Conditioning
Design Specifications
Body Specifications
Maintenance 03-1
Lubricants and Fluids
Maintenance Schedule for Normal Conditions
Listed by Maintenance Item
Maintenance Schedule for Severe Conditions
Engine Electrical 04-15
Special Tools
Starting System
Component Location Index
Circuit Diagram
Starter Circuit Troubleshooting
Starter Solenoid Test
Starter Performance Test
Starter Replacement
Starter Overhaul
Ignition System
Circuit Diagram
Ignition Timing Inspection
Ignition Coil Removal/Installation
Ignition Coil Troubleshooting
Spark Plug Inspection
Charging System
Circuit Diagram
Charging Circuit Troubleshooting
Drive Belt Inspection
Drive Belt Replacement
Drive Belt Auto-tensioner Inspection
Drive Belt Auto-tensioner Replacement
Alternator Replacement
Alternator Overhaul
Cruise Control
Circuit Diagram
Symptom Troubleshooting Index
Cruise Control Communication Circuit Troubleshooting
Control Unit Input Test
Main Switch Test/Replacement
Set/Resume/Cancel Switch Test/Replacement
Actuator Test
Actuator/Cable Replacement
Actuator Cable Adjustment
Clutch Pedal Position Switch Test
Engine Mechanical 05-1
Engine Assembly
Special Tools
Engine Removal
Engine Installation
Engine Mechanical 06-1
Cylinder Head
Special Tools
Engine Compression Inspection
VTEC Rocker Arm Test
VTC Actuator Inspection
Valve Clearance Adjustment
Crankshaft Pulley Removal and Installation
Cam Chain Removal
Cam Chain Installation
Auto-Tensioner Removal/Installation
Chain Case Oil Seal Installation
Cam Chain Inspection
Cylinder Head Cover Removal
Cylinder Head Removal
VTC Actuator, Exhaust Camshaft Sprocket Replacement
Cylinder Head Inspection for Warpage
Rocker Arm Assembly Removal
Rocker Arms and Shafts Disassembly/Reassembly
Rocker Arms and Shafts Inspection
Camshaft Inspection
Valves, Springs and Valve Seals Removal
Valve Inspection
Valve Stem-to-Guide Clearance Inspection
Valve Guide Replacement
Valve Seat Reconditioning
Valves, Springs and Valve Seals Installation
Rocker Arm Assembly Installation
Cylinder Head Installation
Cylinder Head Cover Installation
Engine Mechanical 07-1
Engine Block
Special Tools
Connecting Rod and Crankshaft End Play Inspection
Crankshaft Main Bearing Replacement
Connecting Rod Bearing Replacement
Oil Pan Removal
Crankshaft and Piston Removal
Crankshaft Inspection
Block and Piston Inspection
Cylinder Honing
Piston, Pin and Connecting Rod Replacement
Piston Ring Replacement
Piston Installation
Connecting Rod Bolt Inspection
Crankshaft Installation
Oil Pan Installation
Engine Mechanical 08-1
Engine Lubrication
Special Tools
Oil Pressure Switch Test
Oil Pressure Test
Engine Oil Replacement
Engine Oil Filter Replacement
Oil Filter Holder Replacement
Oil Pump Overhaul
Oil Pressure Switch Replacement
Engine Mechanical 09-1
Intake Manifold and Exhaust System
Intake Manifold Removal and Installation
Exhaust Manifold Removal and Installation
Exhaust Pipe and Muffler Replacement
Engine Cooling 10-1
Cooling System
Radiator Cap Test
Radiator Test
Fan Motor Test
Thermostat Test
Water Pump Inspection
Water Pump Replacement
Coolant Check
Coolant Replacement
Thermostat Replacement
Water Passage Installation
Water Outlet Installation
Radiator and Fans Replacement
Fan Controls
Circuit Diagram
Radiator Fan Circuit Troubleshooting
Radiator Fan Switch Circuit Troubleshooting (Open)
Radiator Fan Switch Circuit Troubleshooting (Short)
Radiator Fan Switch Test
Radiator Fan Switch Replacement
Fuel and Emissions 11-1
Fuel and Emissions Systems
Special Tools
General Troubleshooting Information
DTC Troubleshooting Index
System Descriptions
PGM-FI System
DTC Troubleshooting
MIL Circuit Troubleshooting
DLC Circuit Troubleshooting
Injector Test
Injector Replacement
Primary HO2S Replacement
CKP Sensor Replacement
ECT Sensor Replacement
TDC Sensor Replacement
IAT Sensor Replacement
Knock Sensor Replacement
Secondary HO2S Replacement
VTEC/VTC
DTC Troubleshooting
VTC Oil Control Solenoid Valve Test
CMP Sensor Replacement
VTEC Solenoid Valve Removal/Inspection
Idle Control System
DTC Troubleshooting
A/C Signal Circuit Troubleshooting
Alternator FR Signal Circuit Troubleshooting
PSP Switch Signal Circuit Troubleshooting
Brake Pedal Position Switch Signal Circuit Troubleshooting
Idle Speed Inspection
Fuel Supply System
Fuel Pump Circuit Troubleshooting
Fuel Pressure Relieving
Fuel Pressure Test
Fuel Line Inspection
Fuel Tube/Quick-Connect Fittings Precaution
Fuel Tube/Quick-Connect Fittings Removal
Fuel Tube/Quick-Connect Fittings Installation
Fuel Pressure Regulator Replacement
Fuel Filter Replacement
Fuel Pump/Fuel Gauge Sending Unit Replacement
Fuel Tank Replacement
Fuel Gauge Sending Unit Test
Low Fuel Indicator Light Test
Intake Air System
IMRC System Troubleshooting
Throttle Body Test
Intake Air Bypass Control Thermal Valve Test
Air Cleaner Replacement
Air Cleaner Element Replacement
Throttle Cable Adjustment
Throttle Cable Removal/Installation
Throttle Body Removal/Installation
Throttle Body Disassembly/Reassembly
IMRC Valve Replacement
Catalytic Converter System
DTC Troubleshooting
Catalytic Converter Inspection
Tailpipe Emissions Test
PCV System
PCV Valve Inspection and Test
Evaporative Emission Control System
DTC Troubleshooting
Evaporative Emission (EVAP) System Troubleshooting
EVAP Two Way Valve Test
EVAP Canister Replacement
Clutch 12-1
Special Tools
Clutch Pedal and Clutch Pedal Position Switch Adjustment
Clutch Master Cylinder Replacement
Clutch Master Cylinder Overhaul
Exploded view
Slave Cylinder Replacement
Slave Cylinder Overhaul
Clutch Replacement
M/T - M/T Differential 13-1
Manual Transmission
4WD (Four-wheel Drive) Model Precautions
Special Tools
Transmission Fluid Inspection and Replacement
Back-Up Light Switch Test
Transmission Removal
Transmission Installation
Transmission Disassembly
Reverse Shift Fork Clearance Inspection
Shift Lever Clearance Inspection
Change Lever Assembly Disassembly/Reassembly
Shift Forks Clearance Inspection
Shift Forks Disassembly/Reassembly
Mainshaft Assembly Clearance Inspection
Mainshaft Disassembly
Mainshaft Inspection
Mainshaft Reassembly
Countershaft Assembly Clearance Inspection
Countershaft Disassembly
Countershaft Inspection
Countershaft Reassembly
Synchro Sleeve and Hub Inspection and Reassembly
Synchro Ring and Gear Inspection
Mainshaft Bearing and Oil Seal Replacement
Countershaft Bearing Replacement
Mainshaft Thrust Clearance Adjustment
Transmission Reassembly
Gearshift Mechanism Replacement
M/T Differential
Backlash Inspection
Driven Gear/Carrier Replacement
Carrier Bearings Replacement
Differential Thrust Clearance Adjustment
Transfer Assembly
Backlash Inspection on Car
Transfer Removal
Transfer Installation
Transfer Overhaul
Transfer Inspection
Transfer Disassembly
Transfer Holder Disassembly
Transfer Holder Tapered Roller Bearing Outer Race Replacement
Transfer Drive Gear Bearing Replacement
Transfer Driven Gear Bearing Replacement
Transfer Housing Bearing Outer Race Replacement
Transfer Reassembly
Automatic Transmission 14-1
A/T 14-1
Service Precautions for 4WD Model
Special Tools
System Description
DTC Troubleshooting
Over-drive (O/D) Switch Circuit Troubleshooting
Road Test
Stall Speed Test
Pressure Tests
Shift Solenoid Valves Test
Shift Solenoid Valves Replacement
A/T Clutch Pressure Control Solenoid Valve A Test
A/T Clutch Pressure Control Solenoid Valve A Replacement
A/T Clutch Pressure Control Solenoid Valves B and C Test
A/T Clutch Pressure Control Solenoid Valves B and C Replacement
Mainshaft and Countershaft Speed Sensors Replacement
2nd Clutch Pressure Switch Replacement
3rd Clutch Pressure Switch Replacement
ATF Temperature Sensor Test/Replacement
O/D Switch Test/Replacement
ATF Level Check
ATF Replacement
Transfer Assembly Inspection
Transfer Assembly Removal
Transfer Assembly Installation
ATF Cooler Hoses Replacement
Shift Lever Removal
Shift Lever Installation
Shift Lever Disassembly/Reassembly
Shift Cable Replacement
Shift Cable Adjustment
A/T Gear Position Indicator
Circuit Diagram
Indicator Input Test
Transmission Range Switch Test
Transmission Range Switch Replacement
Indicator Bulb Replacement
A/T Interlock System
Circuit Diagram
Shift Lock System Circuit Troubleshooting
Reverse Lock System Circuit Troubleshooting
Key Interlock System Circuit Troubleshooting
Interlock Control Unit Input Test
Key Interlock Solenoid Test
Shift Lock Solenoid Test/Replacement
Park Pin Switch Test/Replacement
Transmission End Cover
End Cover Removal
Park Lever Stop Inspection and Adjustment
Idler Gear Shaft Bearing Replacement
Control Shaft Oil Seal Replacement
Control Shaft Bearing Replacement
ATF Feed Pipes Replacement
Transmission Housing
Housing and Shaft Assemblies Removal
Bearing Removal
Bearing Installation
Reverse Idler Gear Removal and Installation
Valve Body
Valve Bodies and ATF Strainer Removal
Valve Body Repair
Valve Body Valve Installation
Main Valve Body Disassembly, Inspection, and Reassembly
ATF Pump Inspection
Regulator Valve Body Disassembly, Inspection, and Reassembly
Servo Body Disassembly, Inspection, and Reassembly
Shift Solenoid Valves Installation
Torque Converter Housing
Secondary Shaft Bearing Replacement
Shafts and Clutches
Mainshaft Disassembly, Inspection and Reassembly
Mainshaft 3rd Gear Clearance Inspection
Countershaft Disassembly, Inspection and Reassembly
Selector Hub and 4th Gear Collar Removal
Selector Hub and 4th Gear Collar Installation
Reverse Selector Hub and 1st Gear Removal
Reverse Selector Hub and 1st Gear Installation
Secondary Shaft Disassembly, Inspection and Reassembly
Secondary Shaft Ball Bearing, Idler Gear Removal and Installation
Secondary Shaft 2nd Gear Clearance Inspection
Secondary Shaft 1st Gear Clearance Inspection
Idler Gear Shaft Removal and Installation
Idler Gear/Idler Gear Shaft Replacement
Clutch Disassembly
Clutch Inspection
Clutch Waved-plate Phase Difference Inspection
Clutch Clearance Inspection
Clutch Reassembly
Valve Body
Valve Bodies and ATF Strainer Installation
Shaft Assemblies and Housing Installation
End Cover Installation
A/T Differential
Backlash Inspection
Carrier Bearing Replacement
Differential Carrier/Final Driven Gear Replacement
Carrier Bearing Outer Race Replacement
Carrier Bearing Preload Inspection
Transfer Assembly
Inspection
Disassembly
Transfer Holder Roller Bearing Replacement
Transfer Holder Tapered Roller Bearing Outer Race Removal/Installation
Transfer Driven Gear Bearing Removal/Installation
Transfer Housing Tapered Roller Bearing Outer Race Replacement
Reassembly
Rear Differential 15-1
Special Tools
System Description
Dual Pump System Function Test
Manual Transmission
Automatic Transmission/Manual Transmission
Differential Fluid Inspection and Replacement
Differential Removal
Differential Housing Assembly Removal and Installation
Differential Disassembly
Differential Reassembly
Differential Installation
Differential Mount Replacement
Driveline/Axle 16-1
Special Tools
Driveshaft Inspection
Front Driveshafts Removal
Front Driveshafts Disassembly
Dynamic Damper Replacement
Front Driveshafts Reassembly
Front Driveshafts Installation
Intermediate Shaft Removal
Intermediate Shaft Disassembly
Intermediate Shaft Reassembly
Intermediate Shaft Installation
Rear Driveshafts Removal
Rear Driveshafts Disassembly
Rear Driveshafts Reassembly
Rear Driveshafts Installation
Propeller Shaft Inspection
Propeller Shaft Removal
Propeller Shaft Installation
Steering 17-1
Power Steering
Special Tools
Hard Steering Troubleshooting
Steering Wheel Rotational Play Check
Power Assist Check
Steering Linkage and Gearbox Inspection
Pump Pressure Test
Fluid Leakage Inspection
Fluid Replacement
Hoses and Lines Replacement
Pump Replacement
Pump Overhaul
Steering Wheel Removal
Steering Wheel Disassembly/Reassembly
Steering Wheel Installation
Steering Column Removal and Installation
Steering Column Tilt Operation Check
Steering Column/Tilt Lever Inspection/Adjustment
Steering Lock Replacement
Rack Guide Adjustment
Steering Gearbox Removal
Steering Gearbox Overhaul
Steering Gearbox Installation
Tie-rod Ball Joint Boot Replacement
Suspension 18-1
Front and Rear Suspension
Special Tools
Wheel Alignment
Wheel Bearing End Play Inspection
Wheel Runout Inspection
Ball Joint Removal
Damper Disposal
Front Suspension
Knuckle/Hub/Wheel Bearing Replacement
Stabilizer Link Replacement
Stabilizer Bar Replacement
Lower Arm Replacement
Damper/Spring Replacement
Rear Suspension
Upper Arm Replacement
Trailing Arm Replacement
Brakes 19A-1
Conventional Brake Components
Special Tools
Brake System Operation and Leakage Check
Brake Pedal and Brake Pedal Position Switch Adjustment
Parking Brake Check and Adjustment
Brake System Bleeding
Brake System Indicator Circuit Diagram
Parking Brake Switch Test
Brake Fluid Level Switch Test
Front Brake Pads Inspection and Replacement
Front Brake Disc Inspection
Front Brake Caliper Overhaul
Master Cylinder Disassembly
Master Cylinder Reassembly
Brake Booster Pushrod Clearance Adjustment
Brake Booster Inspection
Brake Booster Replacement
Rear Brake Pads Inspection and Replacement
Rear Brake Disc Inspection
Rear Brake Caliper Overhaul
Parking Brake Drum Inspection
Parking Brake Shoes Replacement
Lining Surface Break-in
Brake Hoses and Lines Inspection
Brake Hose Replacement
Parking Brake Cable Replacement
Brakes 19B-1
ABS Components
Special Tools
System Description
Circuit Diagram
System Connectors
DTC Troubleshooting
ABS Indicator Circuit Troubleshooting
Brake System Indicator Circuit Troubleshooting
ABS Modulator-Control Unit Removal and Installation
Wheel Sensor Inspection
Wheel Sensor Replacement
Body 20-1
Doors
Component Location Index - Front Door
Component Location Index - Rear Door
Front Door Panel Removal/Installation
Front Door Outer Handle Replacement
Front Door Latch Replacement
Front Door Glass and Regulator Replacement
Front Door Glass Outer Weatherstrip Replacement
Front Door Weatherstrip Replacement
Front Door Channel Tape Replacement
Rear Door Panel Removal/Installation
Rear Door Outer Handle Replacement
Rear Door Latch Replacement
Rear Door Glass and Regulator Replacement
Rear Door Glass Outer Weatherstrip Replacement
Rear Door Weatherstrip Replacement
Rear Door Center Pillar Seal Replacement
Rear Door Channel Tape Replacement
Front and Rear Door Glass Adjustment
Front and Rear Door Position Adjustment
Front and Rear Door Striker Adjustment
Mirrors
Power Mirror Replacement
Mirror Holder Replacement
Side Under Mirror Replacement
Rearview Mirror Replacement
Glass
Windshield Replacement
Windshield Side Trim Retainer Installation
Quarter Glass Replacement
Hatch Glass/Hatch Glass Support Strut Replacement
Hatch Glass Disassembly/Reassembly
Hatch Glass Adjustment
Rear Window Molding Replacement
High Mount Brake Light Bracket/Wire Harness Trim Replacement
Hatch Glass Weatherstrip Replacement
Sunroof
Glass Height Adjustment
Glass Replacement
Drain Channel Replacement
Sunshade Replacement
Motor Replacement
Frame and Drain Tube Replacement
Drain Channel Slider and Cable Assembly Replacement
Closing Force and Opening Drag Check
Interior Trim
Trim Removal/Installation - Door Area
Trim Removal/Installation - Rear Side Area
Trim Removal/Installation - Rear Side Pillar Area
Trim Removal/Installation - Cargo Area
Trim Removal/Installation - Tailgate Area
Headliner Removal/Installation
Carpet Replacement
Dashboard
Instrument Panel Removal/Installation
Driver's Dashboard Lower Cover Removal/Installation
Driver's Dashboard Under Cover Removal/Installation
Dashboard Center Panel Removal/Installation
Dashboard Center Tray Removal/Installation
Heater Control Panel Removal/Installation
Dashboard Center Lower Cover Removal/Installation - A/T
Dashboard Center Lower Cover Removal/Installation - M/T
Passenger's Dashboard Under Cover Removal/Installation
Glove Box Removal/Installation
Dashboard Side Vent Removal/Installation
Dashboard Removal/Installation
Steering Hanger Beam Replacement
Seats
Front Seat Removal/Installation
Front Seat Center Table Replacement
Front Seat Armrest Replacement
Front Seat Disassembly/Reassembly - With Manual Height Adjustable
Front Seat Disassembly/Reassembly - Without Manual Height Adjustable
Front Seat Cover Replacement
Rear Seat Removal/Installation
Rear Seat Armrest Replacement
Rear Seat Armrest Cover Replacement
Right Rear Seat Cover Replacement
Left Rear Seat Cover Replacement
Right Rear Seat-back Lock Control Cable Replacement
Rear Seat-back Latch Lever Replacement
Bumpers
Front Bumper Removal/Installation
Rear Bumper Removal/Installation
Hood
Adjustment
Hood Seal Replacement
Hood Insulator Replacement
Tailgate
Tailgate Adjustment
Tailgate Striker Adjustment
Tailgate Wedge Adjustment
Tailgate Support Strut Replacement
Tailgate Weatherstrip Replacement
Fuel Fill Door
Adjustment
Exterior Trim
Front Grille Replacement
Cowl Covers Replacement
Windshield Side Trim Replacement
Roof Side Front Trim Replacement
Roof Side Rear Trim Replacement
Front Wheel Arch Protector Replacement
Rear Wheel Arch Protector Replacement
Door Moldings Replacement
Door Lower Trim Replacement
Side Sill Panel Replacement
Tailgate Lower Trim Replacement
Rear Window Wiper Lifter Replacement
Rear Window Wiper Protection Tape Replacement
Emblem/Sticker Replacement
Fenderwell
Front Inner Fender Replacement
Front Fender Fairing Replacement
Fuel Pipe Protector Replacement
Rear Air Outlet Replacement
Openers
Hood Opener Cable Replacement
Fuel Fill Door Opener Cable Replacement
Hood Latch Replacement
Tailgate Handle Replacement
Tailgate Latch Replacement
Tailgate Stopper Assembly Replacement
Hatch Glass Latch Replacement
Hatch Glass Actuator Replacement
Frame
Sub-frame Replacement
Frame Stiffener Replacement
Frame Repair Chart
HVAC 21-1
Heating
Special Tools
SUPPLEMENAL RESTRAINT SYSTEM (SRS) (If HVAC maintenance is required)
System Description
Circuit Diagram
DTC Troubleshooting
Recirculation Control Motor Circuit Troubleshooting
Heater Control Power and Ground Circuits Troubleshooting
Air Mix Control Motor Test
Air Mix Control Motor Replacement
Mode Control Motor Test
Mode Control Motor Replacement
Recirculation Control Motor Test
Recirculation Control Motor Replacement
Power Transistor Test
Heater Control Panel Removal and Installation
Heater Control Panel Bulb Replacement
Dust and Pollen Filter Replacement (With Air Conditioning)
Blower Unit Removal and Installation
Blower Unit Components Replacement
Heater Unit/Core Replacement
Heater Valve Cable Adjustment
Air Conditioning
A/C Service Tips and Precautions
A/C Refrigerant Oil Replacement
System Description
Circuit Diagram
Condenser Fan Circuit Troubleshooting
Radiator and Condenser Fans Common Circuit Troubleshooting
Compressor Clutch Circuit Troubleshooting
A/C Pressure Switch Circuit Troubleshooting
Evaporator Temperature Sensor Replacement
Evaporator Temperature Sensor Test
Evaporator Core Replacement
Compressor Replacement
Compressor Clutch Check
Compressor Clutch Overhaul
Compressor Thermal Protector Replacement
Compressor Relief Valve Replacement
Condenser Replacement
Receiver/Dryer Desiccant Replacement
Refrigerant Recovery
System Evacuation
System Charging
Refrigerant Leak Test
A/C System Tests
Climate Control
System Description
Circuit Diagram
DTC Troubleshooting
Climate Control Power and Ground Circuits Troubleshooting
ECT Sensor Circuit Troubleshooting
In-car Temperature Sensor Replacement
In-car Temperature Sensor Test
Outside Air Temperature Sensor Replacement
Outside Air Temperature Sensor Test
Sunlight Sensor Replacement
Sunlight Sensor Test
Climate Control Unit Removal and Installation
Climate Control Unit Bulb Replacement
Body Electrical 22A-1
Special Tools
5-step Troubleshooting
Wire Color Codes
Relay and Control Unit Locations
Engine Compartment
Dashboard
Rear
Door
Seat
Wire Harness and Ground Locations
Engine Compartment
Dashoard
Floor
Door
Roof
Rear/Tailgate
Seat
Blower
Fuse/Relay Boxes
Connector to Fuse/Relay Box Index
Power Distribution
Fuse to Component Index
Circuit Identification
Ground Distribution
Under-dash Fuse/Relay Box
Battery
Battery Test
Relays
Power Relay Test
Ignition Switch
Test
Gauges
Self-diagnostic Procedure
Circuit Diagram
Gauge Bulb Replacement
Gauge Assembly Replacement
Coolant Temperature Gauge Troubleshooting
Vehicle Speed Signal Circuit Troubleshooting
VSS Replacement
Outside Air Temperature Indicator Test
Exterior Lights
Circuit Diagram - With Daytime Running Lights
Circuit Diagram - Front/Rear Fog Lights
Circuit Diagram
Circuit Diagram - Front Fog Lights
Circuit Diagram - Rear Fog Light
Circuit Diagram - Headlights Adjuster
Circuit Diagram - Brake Lights
Circuit Diagram - Back-up Lights
Combination Light Switch Test/Replacement
Headlight Adjuster Unit Troubleshooting
Headlight Adjuster Switch Test
Headlight Replacement
Headlight Adjustment
Damaged Headlight Alignment Pin Procedure
Taillight Replacement
High Mount Brake Light Replacement
License Plate Light Replacement
Brake Pedal Position Switch Test
Front Fog Lights Replacement
Front Fog Lights Adjustment
Side Turn Signal Lights Replacement
Turn Signal/Hazard Flasher
Circuit Diagram
Turn Signal/Hazard Relay Input Test
Hazard Warning Switch Test
Interior Lights
Circuit Diagram
Spotlights Test/Replacement
Ceiling Light Test/Replacement
Glove Box Light Test/Replacement
Hatch Glass Latch Switch Test
Tailgate Switch Test/Replacement
Entry Light Control System
Circuit Diagram
Ignition Key Switch Test
Ignition Key Light Test
Stereo Sound System
Circuit Diagram
Audio Unit Removal/Installation
Audio Unit Connector Replacement
Speaker Replacement
Roof Antenna Replacement
Rear Window Defogger
Circuit Diagram
Function Test
Defogger Wire Repair
Noise Condenser Capacity Test
Sunroof
Circuit Diagram
Motor Test
Power Mirrors
Circuit Diagram
Circuit Diagram - With Retract Power Mirror
Function Test
Power Mirror Switch Test/Replacement
Power Mirror Actuator Test
Power Mirror Actuator Replacement
Cigarette Lighter
Circuit Diagram
Replacement
Horns
Circuit Diagram
Horn Test/Replacement
Horn Switch Test
Power Windows
Circuit Diagram - With UP-AUTO Function
Circuit Diagram - Without UP-AUTO Function
Master Switch Input Test - With UP-AUTO Function
Master Switch Input Test - Without UP-AUTO Function
Master Switch Test/Replacement
Passenger's Window Switch Test/Replacement
Driver's Window Motor Test - With UP-AUTO Function
Driver's Window Motor Test - Without UP-AUTO Function
Passenger's Window Motor Test
Resetting the Power Window Control Unit
Keyless/Power Door Lock System
Circuit Diagram - With Super Locking
Circuit Diagram - Without Super Locking
Keyless Receiver Unit Input Test
Control Unit Input Test - Without Super Locking
Control Unit Input Test - With Super Locking
Super Locking Control Unit Input Test
Door Lock Actuator Test
Transmitter Test
Transmitter Programming
Door Lock Switch Test
Tailgate Lock Actuator Test
Hatch Glass Opener Actuator Test
Hatch Glass Opener
Circuit Diagram
Hatch Glass Opener Switch Test/Replacement
Seat Heaters
Circuit Diagram
Seat Heater Test
Seat Heater Relay Test
Seat Heater Switch Test/Replacement
Immobilizer System
System Description
Circuit Diagram
Troubleshooting
Immobilizer Control Unit-Receiver Replacement
Security Alarm System
System Description
Circuit Diagram
Security Control Unit Input Test
Door Lock Knob Switch Test
Hood Switch Test
Door Key Cylinder Switch Test
Tailgate Lock Knob Switch Test
Security Horn Test
Wipers/Washers
System Description
Circuit Diagram - Windshield
Circuit Diagram - Headlight Washer
Circuit Diagram - Rear Window
Washer Motor Test
Wiper/Washer Switch Test/Replacement
Headlight Washer Control Unit Input Test
Rear Wiper Control Unit Input Test
Wiper Motor Test
Wiper Motor Replacement
Washer Reservoir Replacement
Washer Tubes Replacement
Multiplex Control System
Circuit Diagram
System Description
Troubleshooting
Multiplex Control Unit Input Test
Accessory Power Socket
Circuit Diagram
Test/Replacement
Navigation System 22B-1
Special Tools
General Operation
Anti-theft Feature
Symptom Diagnosis
Self-Inertial Navigation Limitations
Global Positioning System (GPS) Limitations
LCD Display Unit Limitations
Symptom Duplication
Service Precautions
System Description
Connector Locations
AVN Unit Inputs and Outputs for Connector A (12P)
AVN Inputs and Outputs for GPS antenna 2P Connector
Overview
Navigation Function
Circuit Diagram
No picture is shown on the display
The picture is missing a Red, Green or Blue color or tone
Satellite mark in the GPS mark is not indicated
Audio driving instructions cannot be heard
Vehicle position does not move on the map
Picture Diagnosis Test
Start-up procedure
Operation keys
Diagnosis items:
Cyclic Diag
Vehicle Position
Start demo mode
In-line Diag
System Links
Monitor Check
Unit Check
Disp
GPS
Navi ECU
System History
Car Status
Yaw Rate
Forced Starting of Display
DVD-ROM Replacement
AVN Unit Removal/Installation
GPS Antenna Removal/Installation
Clock Display Size and Location Adjustment
Restraints 23-1
Restraints
Special Tools
Seat Belts
Front Seat Belt Replacement
Rear Seat Belt Replacement
Inspection
SRS
Precautions and Procedures
System Description
Circuit Diagram
Connectors
DTC Troubleshooting
SRS Indicator Circuit Troubleshooting
Component Replacement/Inspection After Deployment
Driver's Airbag Replacement
Front Passenger's Airbag Replacement
Side Airbag Replacement
Airbag Disposal
Cable Reel Replacement
SRS Unit Replacement
Side Impact Sensor Replacement
OPDS Unit Replacement
Front Sensor Replacement
Supplement 77-1
Special Tools
DTC Troubleshooting
Throttle Body Test
DTC with [D] Indicator Light Troubleshooting Procedures
Wiring diagrams 78-1
Starting System, Charging System, Ignition System
Gauge Assembly (Gauges, Indicator Lights, Dash Lights Brightness Control
Gauge Assembly (Indicator Lights, Warning Lights)
Gauge Assembly (A/T Gear Position Indicator), Cruise Control System
Exterior Lights (With Front Fog Lights, Without Front Fog Lights or Rear Fog Lights
Exterior Lights (With Rear Fog Lights)
Exterior Lights (With Front and Rear Fog Lights)
Exterior Lights (With Daytime Running Lights and Rear Fog Light)
Exterior Lights (Back-up Lights, Brake Lights, Turn Signal/Hazard Flasher)
Exterior Lights (Headlight Adjuster System), Interior Lights, Horns
Power Mirror
Sunroof, Power Windows
Power Window, Cigarette Lighter, Accessory Power Socket
Navigation System, Stereo Sound System
Seat Heater, Wipers/Washers (Headlight Washer)
Wipers/Washers (Windshield Rear)
Multiplex Control System (Fog Light Control, Immobilizer Control, Interlock Control, Intermittent Wiper Control, Entry Lights Control)
Keyless/Power Door Lock System (With Super locking System)
Keyless/Power Door Lock System (Without Super locking System)
Security Alarm System (With Super Locking System)
Security Alarm System (Without Super Locking System)
Interlock System, ABS
SRS
Fan Controls, HVAC
PGM-FI System, Immobilizer System
PGM-FI System
PGM-FI System (A/T)
Overview of chapters-1
Click the appropriate topic: |
