Specifications02-1
Design Specifications02-17 |
02-18
Engine Type Water cooled, 4-stroke DOHC VTEC engine Cylinder arrangement Inline 4-cylinder, transverse Bore and stroke K20A4, K20A5 engines 86 X 86 mm (3.39 X 3.39 in.) K24A1 engine 87 X 99 mm (3.43 X 3.90 in.) Displacement K20A4, K20A5 engines 1,998 cm3 (122 cu in.) K24A1 engine 2,354 cm3 (143 cu in.) Compression ratio K20A4, K20A5 engines 9.8 K24A1 engine 9.6 Valve train Chain drive, DOHC VTEC 4 valves per cylinder Lubrication system Forced, wet sump, with trochoid pump Oil pump displacement at 6,000 engine rpm (min-1) 54.3 l (57.4 US qt, 47.8 Imp qt)/minute Water pump displacement at 6,000 engine rpm (min-1) 82 l (87 US qt, 72 Imp qt)/minute Fuel required K20A4 engine European models UNLEADED gasoline with 95 research octane number or higher K20A4 engine Except European models UNLEADED gasoline with 91 research octane number or higher K20A5 engine KP, KT models LEADED gasoline with 91 research octane number or higher K20A5 engine KW model LEADED gasoline with 88 research octane number or higher K24A1 engine UNLEADED gasoline with 91 research octane number or higher Starter Type Gear reduction Normal output K20A4 (KZ models) engine 1.0 kW K20A4 (KE, KG, KR, KS models) engine 1.1 kW K20A4 (Except KE, KG, KR, KS, KZ models), K20A5 engines 1.2 kW K24A1 engine 1.6 kW Nominal voltage 12 V Hour rating 30 seconds Direction of rotation Clockwise as viewed from gear end Clutch Clutch type M/T Single plate dry, diaphragm spring A/T 3-element torque converter with lock-up clutch Clutch friction material surface area M/T 174 cm2 (26.97 sq in.) Z2C1, Z2M1 Manual Transmission Type Synchronized, 5-speed forward, 1 reverse Primary reduction Direct 1:1 Gear ratio 1st 3.533 2nd 1.769 3rd 1.212 4th 0.921 5th 0.714 Reverse 3.583 Transfer gear Type Hypoid gear Gear ratio 0.904 Differential final gear Type Single helical gear Gear ratio 5.062
02-19
Z2M3
Manual TransmissionType Synchronized, 5-speed forward, 1 reverse Primary reduction Direct 1:1 Gear ratio 1st 3.533 2nd 1.880 3rd 1.212 4th 0.921 5th 0.738 Reverse 3.583 Transfer gear Type Hypoid gear Gear ratio 0.904 Differential final gear Type Single helical gear Gear ratio 4.764 Automatic Transmission Type Electronically controlled automatic, 4-speed forward, 1 reverse Primary reduction Direct 1:1 Gear ratio K20A4, K20A5 engine models 1st 2.684 2nd 1.534 3rd 1.081 4th 0.695 Reverse 2.000 Gear ratio K24A1 engine model 1st 2.684 2nd 1.534 3rd 1.974 4th 0.638 Reverse 2.000 Transfer gear Type Hypoid gear Gear ratio 0.904 Differential final gear Type Single helical gear Gear ratio K20A4, K20A5 engine models 4.562 Gear ratio K24A1 engine model 4.437 Steering Type Power-assisted rack and pinion Overall ratio 15.06 Turns, lock-to-lock 2.64 Steering wheel diameter 360 mm (14.2 in) Suspension Type Front Independent strut with stabilizer, coil spring Rear Double wishbone Shock absorber Front Telescopic, hydraulic, nitrogen gas-filled Rear Telescopic, hydraulic, nitrogen gas-filled Wheel Alignment Camber Front 0° Rear -1° Caster Front 1°45' Total toe Front 0 mm (0 in.) Rear In 2 mm (1/16 in.) Brakes Type of service brake Front Power-assisted self-adjusting ventilated disc Rear Power-assisted self-adjusting solid disc Type of parking brake Mechanical actuating, rear wheels Pad friction surface area Front 42 cm2 (6.5 sq in.) x 2 Rear 21 cm2 (3.3 sq in.) x 2 Shoe friction surface area Rear 49.0 cm2 (7.60 sq in.) x 2
02-20
Tyres Size of front and rear tires 205/70R15 95S Size of spare tire Regular type 205/70R15 95S Compact type T145/80 D16 Air Condition- ing Compressor Type Scroll Number of cylinder ------ Capacity 85.7 ml (5.23 cu in.)/rev. Maximum speed 12,000 rpm (min-1) Lubricant capacity 130 ml (4 1/3 fl oz) Lubricant type ND-OIL8 Condenser Type Corrugated fin Evaporator Type Corrugated fin Blower Type Sirocco fan Motor type 220 W/12 V Speed control Infinite variable Maximum capacity 480 m3 (16.900 cu ft)/h Temperature control Air-mix type Compressor clutch Type Dry, single plate, poly-V belt drive Electrical power consumption at 20 °C (68 °F) 42 W maximum at 12 V Refrigerant Type HFC-134a (R-134a) Capacity 650 - 700 g (22.9 - 24.7 oz) Electrical Ratings Battery 12 V - 36 AH/5 HR, 12 V - 45 AH/20 HR Starter 12 V - 1.2 kW, 1.6 kW Alternator 12 V - 90A Fuses Under-hood fuse relay box 100 A, 40 A, 30 A, 20 A, 15 A, 10 A Under-dash fuse relay box 30A, 20 A, 15 A, 10 A, 7.5 A Light bulbs Headlight high beam 12 V - 60 W Headlight low beam 12 V - 55 W Front turn signal lights 12 V - 21 W Front side marker lights 12 V - 5 W Front parking lights 12 V - 5 W Rear turn signal lights 12 V - - 21 W Side turn signal lights 12 V - 5 W Brake/taillights 12 V - 21/5 W Taillights 12 V - 5 W (Except Taiwan model), 12 V - 3 CP (Taiwan model) Rear fog lights 12 V - 21 W Front fog lights 12 V - 51 W High mount brake light 12 V - 21 W Back-up lights 12 V - 21 W License plate light 12 V - 5 W Ceiling lights 12 V - 8 W Spotlights without roof console 12 V - 8 W Spotlights with roof console 12 V - 4 CP Gauge lights 12 V-1.4 W Indicator lights LED, 12 V - 1.4 W
Specifications02-1
