Rear Differential15-1
Oil Seal Replacement15-16 |
Special Tools Required
Driver 07749-0010000 Attachment, 78 x 80 mm 07NAD-PX40100
- Remove the oil seals (A) from the differential housing.
- NOTE: Be careful not to damage the differential carrier while prying out the seals.
- Install the oil seals (A) squarely using the special tools. Be careful not to damage the lip of the oil seals.
Right side: Installation depth of the oil seal is 9 mm (0.35 in.) below the edge of the differential carrier assembly.
Left side: Install the oil seal (A) flush with the edge of the differential carrier assembly.
15-17
