Honda 2001 Rear Differential15-1
Symptom Troubleshooting Index15-12
Most problems in the unit are to be diagnosed by identifying noises from the gears or bearings.
Care should be taken during diagnosis not to confuse differential noises with those from other drivetrain components.
Symptom
Probable Cause
Remedy
Will not go into 4WD mode
  • Fluid level too low
  • Incorrect fluid type
  • Add fluid
  • Replace
  • Will not return to 2WD mode Incorrect fluid type Drain and fill the differential
    Gear or bearing noises
  • Incorrect or worn out fluid
  • Damaged or chipped gears
  • Add fluid
  • Drain and fill the differential
  • Replace the differential carrier assembly
  • Overheating
  • Add fluid
  • Fluid leak
  • Fluid level too high
  • Clogged breather hose
  • Worn or damaged oil seal
  • Damaged sealing washer
  • Loose mounting bolts or inadequate sealing
  • Lower to proper level
  • Clean or replace
  • Replace
  • Replace
  • Recheck torque or apply sealant
  • Honda 2001 Rear Differential15-1
