Power Distribution 22A-37
Fuse to Component Index
Under-hood Fuse/Relay Box
Component(s) or Circuit(s) Protected
20A
BLU/YEL
Condenser fan motor
BLU/RED
A/C compressor clutch
2
15A
WHT/GRN
Dash lights, Fog light switch, Front parking lights, Front side marker lights, Multiplex
control unit (KG model: daytime running lights), License plate lights, Taillights, Taillight
relay
15A
WHT/BLU
Ceiling lights,Ignition key light, Rear wiper control unit, Spotlights
20A
BLU/BLK
Radiator fan motor
15A
WHT/BLK
Hazard warning light, Security control unit, Turn signal/hazard relay
15A
WHT/BLK
CKP sensor, ECM/PCM, Fuel injectors, IAC valve, Immobilizer control unit-receiver,
PGM-FI main relay 1 and 2, TDC sensor
7
15A
WHT/GRN
ABS modulator-control unit, Brake lights, Cruise control unit, ECM/PCM, Security horn
relay, Security horn
BLU/RED
Horn
8
Not used
9
10A
WHT/RED
AVN unit (With Navigation), Audio unit (Without Navigation), Data link connector, Gauge
assembly, Immobilizer control unit-receiver, Keyless receiver unit, Multiplex control unit,
10
30A
WHT/RED
ABS modulator-control unit (+B MR)
11
20A
BLK/YEL
Noise condenser, Rear window defogger
12
40A
BLU/WHT
Blower motor
13
40A
WHT/BLK
No. 7, 22, 23, 24, 25 fuses (in the under-dash fuse/relay box)
14
40A
WHT/RED
No. 2, 3, 5, 15, 16 fuses (in the under-dash fuse/relay box)
15
15A
RED/YEL
Headlight washer control unit, High beam indicator light, Left headlight
16
20A
WHT
17
15A
RED
Right headlight
18
30A
WHT/BLU
ABS modulator-control unit (+B FSR)
19
100A
Battery, Power distribution
20
50A
WHT
Ignition switch (BAT)
Fuse to Component Index (cont'd) 22A-38
Under-dash Fuse/Relay Box
15A
BLK/WHT
Ignition coils
2
10A
GRN/WHT
Rear accessory power socket
10A
Fuse/relay
box socket
Multiplex control unit (KG model: daytime running lights)
20A
BLU/RED
Front fog lights
10A
GRN/YEL
Alternator, Camshaft position (CMP) sensor, Cruise main switch, Cruise control unit, ELD
unit, EVAP canister purge valve, Intake manifold runner control (IMRC) solenoid valve,
Primary HO2S, Secondary HO2S, Vehicle speed sensor
7.5A
Fuse/relay
box socket
Multiplex control unit (With rear fog light)
7.5A
YEL/GRN
Headlight adjuster switch, Headlight adjuster unit, Power window control unit, Power
window relay, Sunroof open relay, Sunroof close relay
7
20A
GRN
Sunroof motor
8
7.5A
Fuse/relay
box socket
Option connector, Multiplex control unit
YEL/RED
AVN unit (With Navigation), Audio unit (Without Navigation), Interlock control unit (KG
model: daytime running lights), Key interlock solenoid, Key interlock relay, Shift lock
solenoid
9
7.5A
RED/GRN
OPDS unit (With side airbag), Rear wiper control unit, Rear wiper motor, Rear window
washer motor
10
7.5A
Fuse/relay
box socket
YEL
ABS modulator-control unit, A/T reverse relay, Back-up lights, Gauge assembly, Keyless
receiver unit, Security control unit, Shift lock relay
11
Not used
12
7.5A
Fuse/relay
box socket
13
10A
PNK
SRS unit(VB)
14
10A
Fuse/relay
box socket
Option connector
BLK/YEL
A/C compressor clutch relay, Blower motor relay, Condenser fan relay, Climate control
unit (With auto A/C), Heater control panel (Without auto A/C), In-car temperature sensor
assembly (LHD type with auto A/C), Power mirror actuator, Power mirror defogger,
Radiator fan relay, Rear window defogger relay, Recirculation control motor
15
30A
RED/YEL
Headlight washer motor
16
20A
RED/BLK
Seat heaters
17
15A
BLK/YEL
ECM/PCM, Fuel pump, Inertia switch (KG, KR and KE models), SRS unit (VA)
18
15A
YEL/GRN
Cigarette lighter, Rear accessory power socket relay
19
7.5A
YEL/BLK
20
20A
Fuse/relay
box socket
GRN/BLK
Windshield wiper motor, Windshield washer motor
21
Not used
22
20A
GRN/BLK
Front passenger's power window motor
23
20A
GRN/WHT
Driver's power window motor
24
20A
YEL/RED
Left rear power window motor
25
20A
YEL/BLU
Right rear power window motor
Circuit Identification 22A-40
Circuit Identification (cont'd) 22A-41
Circuit Identification (cont'd) 22A-42
Circuit Identification (cont'd) 22A-43
Circuit Identification (cont'd) 22A-44
Circuit Identification (cont'd) 22A-45
Circuit Identification (cont'd) 22A-46
No.2 (15A) UNDER-HOOD FUSE/RELAY BOX
From page 22A-42
No.3 (15A) UNDER-HOOD FUSE/RELAY BOX
From page 22A-42
Circuit Identification (cont'd) 22A-47
