Driveline/Axle16-1
Dynamic Damper Replacement16-8 |
- Remove the inboard joint (see page 16-5) .
- Remove the dynamic damper bands. Be careful not to damage the dynamic damper (see page 16-5) .
- If the boot band is a welded type, cut the boot band.
- If the boot band is a double loop type, lift up the band bend, and push it into the clip.
- If the boot band is a low profile type, pinch the boot band using the commercially available boot band pincers.
- Wrap the splines on the driveshaft with vinyl tape (A) to prevent damage to the dynamic damper.
- Remove the dynamic damper. Be careful not to damage the dynamic damper.
- Adjust the length of the dynamic damper to the figure below.
- Install the dynamic damper band (see step 9 on page 16-11 ).
- Install the inboard joint (see step 1 on page 16-10 ).
Driveline/Axle16-1
