A/T
 Torque Converter Housing14-214  |
Mainshaft Bearing and Oil Seal Replacement
Special Tools Required
Adjustable bearing remover set 07JAC-PH80000 Handle driver 07749-0010000 Driver attachment, 62 x 68 mm 07746-0010500 Driver attachment, 72 x 75 mm 07746-0010600
- Remove the mainshaft bearing and oil seal with the special tool.
- Install the new mainshaft bearing until it bottoms in the housing with the special tools.
- Install the new oil seal flush with the housing with the special tools.
Countershaft Bearing Replacement14-215
- Remove the countershaft bearing with the special tool.
- Install the ATF guide plate (A).
- Install the new countershaft bearing (B) in the housing with the special tools.
Secondary Shaft Bearing Replacement14-216
- Remove the bolt, then remove the lock washer (A) and bearing set plate (B).
- Remove the secondary shaft bearing (A) by heating the housing to about 212 °F (100 °C) with a heat gun (B). Do not heat the housing in excess of 212 °F (100 °C).
- NOTE: Let the housing cool to normal temperature before installing the bearing.
- Install the new O-rings (A) on the ATF guide collar (B), then install the ATF guide collar in the housing.
- Install the new secondary shaft bearing (C) in the direction shown.
- Drive the secondary shaft bearing with the special tools, and install it securely in the housing.
- Check that the bearing groove aligns with the housing surface, then install the bearing set plate with aligning the bearing groove.
- Install the new lock washer and bolt, then bend the lock tab of the lock washer against the bolt head.
Control Shaft Oil Seal Replacement14-217
Handle driver 07749-0010000 Driver attachment, 22 x 24 mm 07746-0010800
A/T
