Driveline/Axle16-1
 Propeller Shaft Installation16-34  |
- Install the propeller shaft (A) onto the rear differential (B) by aligning the reference mark (C).
- Install the center support bearing mounting bolt. Make sure you use a new bolt.
- Install the propeller shaft (A) onto the transfer (B) by aligning the reference mark (C).
- Install the No. 2 propeller shaft protector.
Driveline/Axle16-1
