Sub-frame Replacement
   Front Sub-frame Torque
   NOTE: After loosening the sub-frame mounting bolts, be sure to replace them with new ones.
   Rear Sub-frame Torque
   Frame Stiffener Replacement20-170
   Front Strut Bar, Steering Gearbox Rod and Rear Frame Pipe Torque
   Frame Repair Chart20-171
   Top View
   Unit: mm (in.)
   Ø: Inner diameter
a
For sub-frame Ø16 (0.63)
h
For damper mount Ø11.5 (0.45)
b
For engine mount Ø13 (0.51)
i
For damper center Ø78 (3.07)
c
j
d
k
e1
For M/T transmission mount Ø13 (0.51)
l
e2
For A/T transmission mount Ø13 (0.51)
l1
f1
m
Locating hole Ø27.4 (1.08)
f2
n
Locating hole Ø50 (1.97)
g1
g2
o
Locating hole Ø25 (0.98)
t
Rear damper center Ø68 (2.68)
p
u
For rear cross beam Ø15 (0.59)
p1
u2
Locating hole Right side: Ø13 (0.51)/Left side: Ø15 (0.59)
p2
Locating hole Ø23 (0.91)
v
q
For trailing arm Ø14 (0.55)
w
r
Locating hole Ø20 (0.79)
x
s
   Frame Repair Chart (cont'd)20-173
   Side View
   Unit: mm (in.)
   Ø: Inner diameter
a
h
b
i
c
j
d
k
e1
l
e2
l1
f1
m
f2
n
g1
g2
o
t
p
u
p1
u2
p2
v
q
w
r
x
s
