Rear Differential15-1
Differential Disassembly15-18 |
Special Tools Required
Companion Flange Holder 07PAB-0020000
- Remove the drain plug (A) and the oil filler plug (B) with sealing washers (C).
- Raise the locknut tub (A) from the groove of the clutch guide, making sure that the tab completely clears the groove to prevent damaging the clutch guide.
- Install the special tools on the companion flange.
- Loosen the locknut (A) counterclockwise so that its tab (B) comes out from the groove (C) in the clutch guide.
15-19
- Tighten the locknut (A) until its tab (B) aligns with the groove (C).
- Remove any dirt from inside of the groove in the clutch guide, then loosen the locknut.
- Remove the locknut (A), the disc spring washer (B), the back-up ring (C), the O-ring (D) and the companion flange (E).
- Remove the eight mounting bolts (A) in a crisscross pattern in several steps, then remove the torque control differential case (B) and the dowel pin (C).
- Remove the shim (A) and the clutch guide (B).
Differential Disassembly (cont'd)15-20
