Body Electrical22A-1
Horns 22A-140 |
Horns 22A-140
Component Location Index
NOTE: LHD type is shown, RHD type is similar.
Test, page 22A-62 Test, page 22A-157 Replacement, page 23-141 Test, page 22A-156 ; Replacement, page 22A-156
Circuit Diagram 22A-141
Horn Test/Replacement 22A-141
- Remove the front bumper (see page 20-130) .
- Disconnect the 1P connector (A), and remove the horn (B).
- Test the horn by connecting battery power to the terminal (A) and ground to the bracket (B). The horn should sound.
Horn Switch Test 22A-142
- Remove the steering column covers (see page 17-24) .
- Disconnect the dashboard wire harness B 5P connector (A) from the cable reel (B).
- Check for continuity between the cable reel No. 2 terminal and body ground with the horn switch pushed. There should be continuity. If there is no continuity, go to step 4.
- Remove the driver's airbag assembly (see page 23-135) .
- Disconnect the horn switch positive terminal 1P connector.
- Check for continuity between the cable reel No.2 terminal (A) and the horn switch positive terminal (B).
- If there is no continuity, replace the cable reel (see page 23-141) .
- If there is continuity, the cable reel OK, check the steering wheel, the horn switch, and the steering column (ground path).
Horns 22A-140 |
