Fuel and Emissions11-1
Idle Control System11-139 |
Component Location Index
*: The illustration shows LHD model.
Troubleshooting, page 11-145 Troubleshooting, page 11-140
DTC Troubleshooting11-140
DTC P1519 (14-3): IAC Valve Circuit Malfunction
- Reset the ECM/PCM (see page 11-4) .
- Turn the ignition switch ON (II).
Is DTC P1519 indicated?
Yes : Go to step 3.
No : Intermittent failure, system is OK at this time. Check for poor connections or loose wires at the IAC valve and at the ECM/PCM.
- Turn the ignition switch OFF.
- Disconnect the IAC valve 3P connector.
- Measure voltage between IAC valve 3P connector terminal No. 2 and body ground.
Is there battery voltage?
Yes : Go to step 7.
No : Repair open in the wire between the IAC valve and the PGM-FI main relay.
- Check for continuity between body ground and IAC valve 3P connector terminal No. 1.
Is there continuity?
Yes : Go to step 9.
No : Repair open in the wire between the IAC valve and G101.
- Disconnect the negative cable from the battery.
- Disconnect ECM/PCM connector A (31P).
- Check for continuity between body ground and ECM/PCM connector terminal A12.
Yes : Repair short in the wire between the IAC valve and the ECM/PCM (A12).
No : Go to step 12.
11-141
Yes : Go to step 14.
No : Repair open in the wire between the IAC valve and the ECM/PCM (A12).
- Reconnect the IAC valve 3P connector.
- Reconnect the negative cable to the battery.
- Measure voltage between body ground and ECM/PCM connector terminal A12.
Yes : Substitute a known-good ECM/PCM and recheck (see page 11-5). If symptom/indication goes away, replace the original ECM/PCM.
No : Replace the IAC valve.
A/C Signal Circuit Troubleshooting11-142
- Momentarily connect ECM/PCM connector terminals A24 and E18 with a jumper wire several times.
Is there a clicking noise from the A/C compressor clutch?
Yes : Go to step 3.
No : Go to step 6.
Does the A/C operate?
Yes : The air conditioning signal is OK.
No : Substitute a known-good ECM/PCM and recheck (see page 11-5). If symptom/indication goes away, replace the original ECM/PCM.
- Momentarily connect the under-hood fuse/relay box 14P connector terminal No. 10 to body ground with a jumper wire several times.
Is there clicking noise from the A/C compressor clutch?
Yes : Repair open in the wire between the ECM/PCM (E18) and the A/C clutch relay.
No : Check the A/C system for other symptoms.
Alternator FR Signal Circuit Troubleshooting11-143
- Disconnect the alternator 4P connector.
- Measure voltage between ECM/PCM connector terminals A24 and B13.
Is there about 5 V?
Yes : Go to step 4.
No : Go to step 14.
- Reconnect the alternator 4P connector.
- Start the engine. Hold the engine at 3,000 rpm (min-1) with no load (in Park or neutral) until the radiator fan comes on, then let it idle.
Does the voltage decrease when the headlights and rear window defogger are turned on?
Yes : The alternator FR signal is OK.
No : Go to step 8.
- Disconnect ECM/PCM connector B (24P).
- Connect alternator 4P connector terminal No. 4 and body ground with a jumper wire.
Yes : Test the alternator (see page 04-27).
No : Repair open in the wire between the ECM/PCM (B13) and the alternator.
Alternator FR Signal Circuit Troubleshooting (cont'd)11-144
Yes : Repair short in the wire between the ECM/PCM (B13) and the alternator.
PSP Switch Signal Circuit Troubleshooting11-145
Is there less than 1.0 V?
Yes : Go to step 3.
No : Go to step 6.
- Start the engine.
- Turn the steering wheel to the full lock position.
- Measure voltage between ECM/PCM connector terminals A24 and E16.
Yes : The PSP switch signal is OK.
No : Go to step 13.
- Disconnect the PSP switch 2P connector.
- At the harness side, connect PSP switch 2P connector terminals No. 1 and No. 2 with a jumper wire.
Yes : Replace the PSP switch.
No : Go to step 11.
- Check for continuity between PSP switch 2P connector terminal No. 2 and body ground.
Yes : Repair open in the wire between the PSP switch and ECM/PCM (E16).
No : Repair open in the wire between the PSP switch and G301.
PSP Switch Signal Circuit Troubleshooting (cont'd)11-146
No : Go to step 17.
- Disconnect ECM/PCM connector E (31P).
- Check for continuity between body ground and ECM/PCM connector terminal E16.
Yes : Repair short in the wire between ECM/PCM (E16) and the PSP switch.
Brake Pedal Position Switch Signal Circuit Troubleshooting11-146
Are the brake lights on without pressing the brake pedal?
Yes : Inspect the brake pedal position switch
(see page 19A-5).![]()
No : Go to step 2.
Do the brake lights come on?
Yes : Go to step 3.
No : Go to step 4.
Yes : The brake pedal position switch signal is OK.
No : Repair open in the wire between the ECM/PCM (E22) and the brake pedal position switch.
11-147
Is the fuse OK?
Yes : Repair open in the wire between the brake pedal position switch and the No. 7 HORN, STOP (15A) fuse. Inspect the brake pedal position switch (see page 19A-5).
No : Repair short in the wire between the ECM/PCM (E22) and the No. 7 HORN, STOP (15A) fuse. Replace the No. 7 HORN, STOP (15A) fuse.
Idle Speed Inspection11-148
Leave the Idle Air Control (IAC) valve connected. Before checking the idle speed, check these items:
The Malfunction Indicator Lamp (MIL) has not been reported on. Ignition timing Spark plugs Air cleaner PCV system
- Disconnect the Evaporative Emission (EVAP) canister purge valve 2P connector.
- Connect a tachometer (A) to the test tachometer connector (B).
- Check the idle speed with no-load conditions: headlights, blower fan, rear defogger, radiator fan, and air conditioner are not operating.
Idle speed should be:
M/T 650 ± 50 rpm (min-1) A/T 650 ± 50 rpm (min-1) (in Park or neutral)
- Idle the engine for 1 minute with heater fan switch on HI and air conditioner on, then check the idle speed.
M/T 700 ± 50 rpm (min-1) A/T 700 ± 50 rpm (min-1) (in Park or neutral)
- NOTE: If the idle speed is not within specification,
go to the Symptom Troubleshooting Index.- Reconnect the EVAP canister purge valve 2P connector.
- NOTE: You can use the scan tool or Honda PGM Tester to inspect idle speed.
