Body Electrical22A-1
Under-dash Fuse/Relay Box 22A-58 |
Removal and Installation
SRS components are located in this area. Review the SRS component locations (see page 23-14) , and precautions and procedures (see page 23-16) in the SRS section before performing repairs or service.
Removal
- Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons.
- Disconnect the battery negative cable, then disconnect the positive cable, and wait at least three minutes.
- Remove the dashboard lower cover (see page 20-88) .
- Disconnect the connectors from the fuse side of the under-dash fuse/relay box.
- Remove the mounting bolt and the under-dash fuse/relay box (A).
- Disconnect the connectors from the back of the under-dash fuse/relay box, and remove the fuse/relay box.
- NOTE: The SRS connector is a spring-loaded lock type (see page 23-20) .
Installation
- Install the under-dash fuse/relay box in the reverse order of removal and connect all connectors to the under-dash fuse/relay box.
- Install the dashboard lower cover.
- Connect both the negative cable and positive cable to the battery.
- Enter the anti-theft code for the radio, then enter the customer's radio station presets.
- Confirm that all systems work properly.
