Driveline/Axle16-1
 Intermediate Shaft Reassembly16-21  |
Exploded View
Intermediate Shaft Reassembly (cont'd)16-22
Special Tools Required
Driver 07749-0010000 Attachment, 52 x 55 mm 07746-0010400 Attachment, 35 mm I.D. 07746-0030400 Oil seal driver 07GAD-PH70201 NOTE: Refer to the Exploded View as needed during this procedure.
- Clean the disassembled parts with solvent, and dry them with compressed air. Do not wash the rubber parts with solvent.
- Press the intermediate shaft bearing (A) into the bearing support (B) using the special tools and a press.
- Seat the internal snap ring into the groove of the bearing support.
- Press the intermediate shaft (A) into the shaft bearing (B) using the special tool and a press.
- Seat the external snap ring (A) into the groove of the intermediate shaft (B).
16-23
Driveline/Axle16-1
