Body20-1
Overview of this chapter |
Body20-1
Doors 20-2
Mirrors 20-38
Glass 20-43
Sunroof 20-63
Interior Trim 20-75
Dashboard 20-87
Seats 20-102
Bumpers 20-130
Hood 20-132
Tailgate 20-135
Fuel Fill Door 20-138
Exterior Trim 20-139
Fenderwell 20-155
Openers 20-158
Frame 20-168
SUPPLEMENTAL RESTRAINT SYSTEM (SRS) (If body maintenance is required)
The CR-V SRS includes a driverís airbag in the steering wheel hub, a passengerís airbag in the dashboard above the glove box, seat belt tensioners in the front seat belt retractors, seat belt buckle tensioners in the front seat belt buckles, and side airbags in the front seat-backs. Information necessary to safely service the SRS is included in this Service Manual. Items marked with an asterisk ( ) on the contents page include or are located near SRS components.
Servicing, disassembling, or replacing these items will require special precautions and tools, and should be done only by an authorized Honda dealer.
To avoid rendering the SRS inoperative, which could lead to personal injury or death in the event of a severe frontal collision, all SRS service work must be performed by an authorized Honda dealer. Improper service procedures, including incorrect removal and installation of the SRS could lead to personal injury caused by unintentional deployment of the airbags and side airbags. Do not bump the SRS unit. Otherwise, the systemmay fail in a collision, or the airbags may deploy when the ignition switch is ON (II). SRS electrical connectors are identified by yellow color coding. Related components are located in the steering column, front console, dashboard, dashboard lower panel, in the dashboard above the glove box, in the front seats, and around the floor. Do not use electrical test equipment on these circuits.
Body20-1
