Fuse/Relay Boxes 22A-35
Connector to Fuse/Relay Box Index
Under-hood Fuse/Relay Box
A
11
2
Engine compartment wire harness
A/C compressor clutch relay
B
16
Blower motor relay
8
C
12
12
Condenser fan relay
D
15
14
E
14
7
ELD unit
13
Horn relay
Headlight relay 1
9
Headlight relay 2
10
Radiator fan relay
Rear window defogger relay
7
T1 (Battery)
2
Starter sub-harness
T101 (Alternator)
Starter sub-harness
Connector to Fuse/Relay Box Index (cont'd) 22A-36
Under-dash Fuse/Relay Box
A
2
Dashboard wire harness
B
C
D
12
ECM/PCM wire harness
E
13
F
19
12
G
9
10
H
8
I
20
J
21
8
K
23
17
L
24
10
M
22
12
N
27
O
26
12
P
7
18
Q
8
R
10
Power Window relay
12
S
25
2
Starter cut relay
14
T
18
Multiplex control unit service check connector
Taillight relay
13
Turn signal/hazard relay
11
U
15
Optional connector
V
16
Optional connector
W (Memory erase signal (MES)
connector)
17
2
X
28
8
Dashboard wire harness B (Plugs directly into the multiplex control
unit)
Y
29
13
Dashboard wire harness A (Plugs directly into the multiplex control
unit)
