Honda 2001 Body Electrical22A-1
Keyless/Power Door Lock System 22A-158
Component Location Index
NOTE: LHD type is shown, RHD type is similar.
TRANSMITTER
Test, page 22A-196 Programming, page 22A-197
7
RIGHT REAR DOOR LOCK ACTUATOR
Test, page 22A-193
2
DRIVER'S DOOR LOCK SWITCH
Test, page 22A-198
8
HATCH GLASS OPENER ACTUATOR
Test, page 22A-200
IGNITION KEY SWITCH
Test, page 22A-123
9
TAILGATE LOCK ACTUATOR
Test, page 22A-199
MULTIPLEX CONTROL UNIT
Input Test, page 22A-185
10
TAILGATE SWITCH
Test, page 22A-120 Replacement, page 22A-120
KEYLESS RECEIVER UNIT
Input Test, page 22A-184
11
LEFT REAR DOOR LOCK ACTUATOR
Test, page 22A-193
FRONT PASSENGER'S DOOR LOCK ACTUATOR
Test, page 22A-193
12
DRIVER'S DOOR LOCK ACTUATOR/KNOB SWITCH
Actuator Test, page 22A-193 Knob Switch Test, page 22A-226
22A-159
KE model:
Test, page 22A-199
10
DRIVER'S SUPER LOCKING CONTROL UNIT
Input Test, page 22A-191
TAILGATE KNOB SWITCH
Test, page 22A-231
11
DRIVER'S DOOR KEY CYLINDER SWITCH
Input Test, page 22A-230
2
Test, page 22A-200
12
DRIVER'S SUPER LOCKING ACTUATOR/KNOB SWITCH
LEFT REAR DOOR SWITCH
13
DRIVER'S DOOR SWITCH
LEFT REAR SUPER LOCKING CONTROL UNIT
14
RIGHT REAR SUPER LOCKING CONTROL UNIT
FRONT PASSENGER'S SUPER LOCKING ACTUATOR/KNOB SWITCH
15
RIGHT REAR SUPER LOCKING ACTUATOR/KNOB SWITCH
FRONT PASSENGER'S SUPER LOCKING CONTROL UNIT
16
RIGHT REAR DOOR SWITCH
7
17
FRONT PASSENGER'S DOOR SWITCH
8
18
LEFT REAR SUPER LOCKING ACTUATOR/KNOB SWITCH
9
IGNITION KEY SWITCH
Test, page 22A-123
19
TAILGATE SWITCH
Circuit Diagram - With Super Locking 22A-160
22A-161
Circuit Diagram - With Super Locking (cont'd) 22A-162
Circuit Diagram - Without Super Locking 22A-163
HORN
To page 22A-183
Circuit Diagram - Without Super Locking (cont'd) 22A-164
No.7 (15A) FUSE
From page 22A-182
Keyless Receiver Unit Input Test 22A-165
  1. Remove the heater control panel or climate control unit (see page 21-24) .
  2. Disconnect the 5P connector (A) from the keyless receiver unit (B).
  3. Inspect the connector and socket terminals to be sure they are all making good contact.
  4. If the terminals are bent, loose or corroded, repair them as necessary, and recheck the system.
  5. If the terminals are OK, go to step 5.
  6. Reconnect the connector, and make these input tests at the connector.
  7. If any test indicates a problem, find and correct the cause, then recheck the system.
  8. If all the input tests prove OK, go to step 5.
    Cavity
    Wire
    Test condition
    Test: Desired result
    Possible cause if result is not obtained
    1 BLK Under all conditions Check for continuity to ground: There should be continuity.
  9. Poor ground (G502)
  10. An open in the wire
  11. 3 YEL Ignition switch ON (II) Check for voltage to ground: There should be battery voltage.
  12. Blown No. 10 (7.5A) fuse in the under-dash fuse/relay box
  13. An open in the wire
  14. Ignition switch OFF Check for voltage to ground: There should be no voltage.
  15. Short to power on No. 10 (7.5A) fuse circuit
  16. 5 WHT/RED Under all conditions Check for voltage to ground: There should be battery voltage.
  17. Blown No. 9 (10A) fuse in the under-hood fuse/relay box
  18. An open in the wire
  19. Disconnect the connector, and make this input test at the connector.
  20. If the test indicates a problem, find and correct the cause, then recheck the system.
  21. If the input test prove OK, replace the keyless receiver unit.
    Cavity
    Wire
    Test condition
    2 BLU/ORN Ignition switch OFF, under-dash fuse/relay box connector K (17P) disconnected Check for continuity between the No. 2 terminal and the No. 2 terminal of the under-dash fuse/relay box connector K (17P). There should be continuity.
  22. An open in the wire
  23. A short to ground in the wire
  24. Check for continuity between the No. 2 terminal and body ground: There should be no continuity.
Control Unit Input Test - Without Super Locking 22A-166
NOTE: For the hatch glass unlock button test, refer to the rear wiper control unit input test (see page 22A-246) .
  1. Before testing, troubleshoot the multiplex control system (see page 22A-261) .
  2. Remove the dashboard lower cover.
  3. Disconnect the under-dash fuse/relay box connectors.
  4. NOTE: All connectors are wire side of female terminals.
  5. Inspect the connector and socket terminals to be sure they are all making good contact.
  6. If the terminals are bent, loose or corroded, repair them as necessary, and recheck the system.
  7. If the terminals look OK, go to step 5.
22A-167
  1. With the connectors still disconnected, make these input tests at the connector.
  2. If any test indicates a problem, find and correct the cause, then recheck the system.
  3. If all the input tests prove OK, go to step 6.
    Cavity
    Wire
    Test condition
    J4 BLK Under all conditions Check for continuity to ground: There should be continuity.
  4. Poor ground (G301)
  5. An open in the wire
  6. J2 WHT/RED Under all conditions Check for voltage to ground: There should be battery voltage.
  9. J7 WHT Under all conditions Check for voltage to ground: There should be battery voltage.
  10. Blown No. 16 (20A) fuse in the under-hood fuse/relay box
  11. An open in the wire
  12. M7 YEL/BLK Connect J7 terminal to M6 [or M9] terminal, and M9 [or M6] terminal to F3 terminal. Check actuator operation: The driver's door lock actuator should lock [or unlock].
  13. Blown No. 16 (20A) fuse in the under-hood fuse/relay box
  14. Faulty driver's door lock actuator
  15. An open in the wire
  16. M9 YEL/GRN
    M6 YEL/BLK Connect J7 terminal to M7 [or M8] terminal, and M8 [or M7] terminal to F3 terminal. Check actuator operation: The front passenger's door lock actuator should lock [or unlock].
  17. Blown No. 16 (20A) fuse in the under-hood fuse/relay box
  18. Faulty front passenger's door lock actuator
  19. An open in the wire
  20. M8 YEL
    P16 YEL Connect J7 terminal to P17 [or P16] terminal, and P16 [or P17] terminal to F3 terminal. Check actuator operation: The both rear door lock actuator should lock [or unlock].
  21. Blown No. 16 (20A) fuse in the under-hood fuse/relay box
  22. Faulty left or right door lock actuator
  23. An open in the wire
  24. P17 YEL/BLK
    K2 BLU/ORN Under all conditions Check for continuity between the K2 terminal and the keyless receiver unit 5P connector No. 2 terminal with 5P connector disconnected: There should be continuity.
  25. An open in the wire
  26. Y2* BLU/ORN Under all conditions Check for continuity between the Y2 terminal and the security control unit A17 terminal with the security control unit 20P connector disconnected: There should be continuity.
  27. An open in the wire
  28. Y3* LT GRN/ BLK Under all conditions Check for continuity between the Y3 terminal and the security control unit A6 terminal with the security control unit 20P connector disconnected: There should be continuity.
  29. An open in the wire
  30. *: With security system
Control Unit Input Test - Without Super Locking (cont'd) 22A-168
  1. Reconnect all connections to the under-dash fuse/relay box, and make sure these input tests at the appropriate connectors on the under-dash fuse/relay box.
  3. If all the input tests prove OK, the multiplex control unit must be faulty, replace the under-dash fuse/relay box assembly.
    Cavity
    Wire
    Test condition
    P18 RED Tailgate open Check for voltage to ground: There should be 1 V or less.
  4. Poor ground (G601 or G553)
  5. Faulty trunk or tailgate switch
  6. An open in the wire
  7. Tailgate closed Check for voltage to ground: There should be 5 V or more.
  8. Faulty trunk switch
  9. Short to ground
  10. Q3 GRN Driver's door open Check for voltage to ground: There should be 1 V or less.
  11. Faulty driver's door switch
  12. An open in the wire
  13. Driver's door closed Check for voltage to ground: There should be 5 V or more.
  14. Faulty driver's door switch
  15. Short to ground
  16. Q4 LT GRN/ RED Passenger's door open Check for voltage to ground: There should be 1 V or less.
  17. Faulty passenger's door switch
  19. Passenger's door closed Check for voltage to ground: There should be 5 V or more.
  20. Faulty passenger's door switch
  21. Short to ground
  22. X5 RED/WHT Ignition key inserted into the ignition switch Check for voltage to ground: There should be 1 V or less.
  23. Poor ground (G401)
  24. Faulty ignition key switch
  26. Ignition key removed from the ignition switch Check for voltage to ground: There should be 5 V or more.
  27. Faulty ignition key switch
  28. Short to ground
  29. Y7 WHT/BLK Driver's door lock knob switch unlocked Check for voltage to ground: There should be less than 1 V.
  30. Poor ground (G501)
  31. Faulty driver's door lock knob switch
  32. An open in the wire
  33. Driver's door lock knob switch locked Check for voltage to ground: There should be 5 V or more.
  34. Faulty driver's door lock knob switch
  35. Short to ground
  36. Y8 YEL/RED Driver's door lock knob switch locked Check for voltage to ground: There should be 1 V or less.
  37. Poor ground (G501)
  38. Faulty driver's door lock knob switch
  39. An open in the wire
  40. Driver's door lock knob switch unlocked Check for voltage to ground: There should be 5 V or more.
  41. Faulty driver's door lock knob switch
  42. Short to ground
  43. Y10 WHT/GRN Driver's door lock switch unlocked Check for voltage to ground: There should be 1 V or less.
  44. Poor ground (G501)
  45. Faulty driver's door lock switch
  46. An open in the wire
  47. Driver's door lock switch in neutral Check for voltage to ground: There should be 5 V or more.
  48. Faulty driver's door lock switch
  49. Short to ground
  50. Y12 WHT/BLU Driver's door lock switch locked Check for voltage to ground: There should be 1 V or less.
  51. Poor ground (G501)
  52. Faulty driver's door lock switch
  53. An open in the wire
  54. Driver's door lock switch in neutral Check for voltage to ground: There should be 5 V or more.
  55. Faulty driver's door lock switch
  56. Short to ground
  57. P2 BLK/YEL Press the keyless transmitter hatch glass unlock button Check for voltage to ground: There should be battery voltage for a moment.
  58. Poor ground (G601, G701)
  59. Faulty hatch glass opener actuator
  60. An open in a wire
  61. C11 BLU Under all conditions Attach to ground: Parking, side marker, license plate lights and taillights should come on.
  62. Blown No. 2 (15A) fuse in the under-hood fuse/relay box
  63. Faulty taillight relay
  64. Faulty under-dash fuse/relay box
  65. An open in the wire
  66. F7 BLU/RED Under all conditions Attach to ground: Headlights should come on.
  67. Blown No. 15 or 17 (15A) fuse in the under-hood fuse/relay box
  68. Faulty headlight relay 1 or 2
  69. An open in the wire
  70. J6 ORN Under all conditions Attach to ground: The horn should sound.
  71. Blown No. 7 (15A) fuse in the under-hood fuse/relay box
  72. Faulty horn relay
  73. Faulty horn
  74. An open in the wire
Control Unit Input Test - With Super Locking 22A-169
Control Unit Input Test - With Super Locking (cont'd) 22A-170
  1. Reconnect the connectors, and make these input tests at the connector.
    Cavity
    Wire
    Test condition
  4. Blown No. 9 (10A) fuse in the under-hood fuse/relay box
  6. J7 WHT Under all conditions Check for voltage to ground: There should be battery voltage.
  9. K2 BLU/ORN Under all conditions Check for continuity between the K2 terminal and the keyless receiver unit 5P connector No. 2 terminal with the 5P connector disconnected: There should be continuity.
  11. M6 YEL/BLK Connect J7 terminal to M7 [or M8] terminal, and M8 [or M7] terminal to F3 terminal. Check actuator operation: The front passenger's door lock actuator should lock [or unlock].
  12. Blown No. 16 (20A) fuse in the under-hood fuse/relay box
  13. Faulty actuator
  14. Faulty super locking control unit
  16. M8 YEL
  18. Faulty actuator
  19. Faulty super locking control unit
  20. An open in the wire
  21. M9 YEL/GRN
    P17 YEL/BLK Connect J7 terminal to P17 [or P16] terminal, and P16 [or P17] terminal to F3 terminal. Check actuator operation: The left rear door, right rear door and tailgate lock actuator should lock [or unlock].
  22. Blown No. 16 (20A) fuse in the under-hood fuse/relay box
  23. Faulty actuator
  24. Faulty left rear or right rear super locking control unit.
  26. P16 YEL
  27. Poor ground (G301)
  28. An open in the wire
22A-171
  1. Reconnect all connector to the under-dash fuse/relay box, and make sure these input tests at the appropriate connectors on the under-dash fuse/relay box.
    Cavity
    Wire
    Test condition
  4. Poor ground (G601)
  5. Faulty tailgate latch switch
  8. Poor ground (G401)
  9. Faulty ignition key switch
  11. Ignition key removed from the ignition switch Check for voltage to ground: There should be 5 V or more.
  12. Faulty driver's door switch
  14. Driver's door closed Check for voltage to ground: There should be 5 V or more.
    Q4 LT GRN/ RED Passengers door open Check for voltage to ground: There should be 1 V or less.
  15. Faulty passenger's door switch
  16. An open in the wire
  17. Passenger's door closed Check for voltage to ground: There should be 5 V or more.
    Y4 BLU Front passenger's, tailgate, left rear or right rear door lock knob switch unlocked Check for voltage to ground: There should be 1 V or less.
  18. Faulty front passenger's, tailgate, left rear or right rear door lock knob switch
  19. Poor ground (G502, G551, G552, G601, G701)
  21. X6 WHT/RED Driver's door key cylinder switch lock Check for voltage to ground: There should be 1 V or less.
  22. Faulty driver's door key cylinder switch
  23. Poor ground (G501)
  24. An open in the wire
  25. Driver's door key cylinder switch in neutral Check for voltage to ground: There should be 5 V or more.
    Y13 WHT Driver's door key cylinder switch unlocked Check for voltage to ground: There should be 1 V or less.
  26. Poor ground (G501)
  27. Faulty driver's door lock knob switch
  29. Driver's door lock knob switch locked Check for voltage to ground: There should be 5 V or more.
  30. Faulty driver's door lock knob switch
  31. Short to ground
  32. Y8 YEL/RED Driver's door lock knob switch locked Check for voltage to ground: There should be 1 V or less.
  33. Poor ground (G501)
  35. An open in the wire
  36. Driver's door lock knob switch unlocked Check for voltage to ground: There should be 5 V or more.
  37. Faulty driver's door lock knob switch
  38. Short to ground
  39. Y2 BLU/ORN Under all conditions Check for continuity between the Y2 terminal and the security control unit A17 terminal with the security control unit 20P connector disconnected: There should be continuity.
  40. An open in the wire
  41. Y3 LT GRN/ BLK Under all conditions Check for continuity between the Y3 terminal and the security control unit A6 terminal with the security control unit 20P connector disconnected: There should be continuity.
  42. An open in the wire
  43. P2 BLK/YEL Press the keyless transmitter hatch glass unlock button Check for voltage to ground: There should be battery voltage for a moment.
  44. Poor ground (G601, G701)
  45. Faulty hatch glass opener actuator
  46. An open in a wire
Super Locking Control Unit Input Test 22A-172
  1. Remove the each door panel (see page 20-6) .
  2. Disconnect the 8 P connector (A) from the super locking control unit (B).
  5. If the terminals look OK, make the following input tests at the connector.
  6. If a test indicates a problem, find and correct the cause, then recheck the system.
  7. If all the input tests prove OK, the control unit must be faulty, replace it.
22A-173
Cavity
Wire
Test condition
3 BLK Under all conditions Check for continuity to ground: There should be continuity.
  • Poor ground (G501, G502, G551, G552)
  • An open in the wire
  • 2 YEL/BLK Connect the No. 2 terminal to the No. 7 terminal and the No. 6 terminal to the No. 3 terminal momentarily with ignition switch ON (II) Check actuator operation: The actuator should lock.
  • Faulty door lock actuator
  • 7 LT GRN [GRY]
    5 YEL/GRN [YEL] Connect the No. 5 terminal to the No. 6 terminal and the No. 7 terminal to the No. 3 terminal momentarily with ignition switch ON (II) Check actuator operation: The actuator should unlock.
    6 GRN/BLK [GRN/WHT or GRN/ RED]
    4 BLU/BLK [BLU/WHT or BLU/ RED] Under all conditions Check for continuity between the No. 4 terminal and No. 2 terminal of the actuator. There should be continuity.
  • [ ]: Passenger's
  • Door Lock Actuator Test 22A-174
    Driver's Door without Super Locking:
    1. Remove the driver's door panel (see page 20-9) .
    2. Disconnect the 2P connector (A) from the actuator.
    3. Check actuator operation by connecting power and ground according to the table. To prevent damage to the actuator, apply battery voltage only momentarily.
    4. If the actuator does not work as specified, replace it.
    Driver's Door with Super Locking:
    2. Disconnect the 6P connector (A) from the actuator.
    22A-175
    Passenger's Door without Super Locking:
    1. Remove the passenger's door panel (see page 20-9) .
    Passenger's Door with Super Locking:
    Transmitter Test 22A-176
    NOTE:
  • If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
  • If any door is open, you cannot lock the door with the transmitter.
  • If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically.
  • The doors do not lock or unlock with the transmitter if the ignition key is in the ignition switch.
  • Using a keyless entry checker (07MAJ-SP00300):
    Put the transmitter (A) on the keyless entry checker (B) and press the button.
  • If the ray indicator light (C) does not come on, check for:
  • a dead or low battery.
  • faulty transmitter.
  • If the ray indicator light comes on, the transmitter is OK.
  • NOTE: When the transmitter battery was replaced, aim the transmitter at the receiver, and press the transmitter button six times. The receiver is located behind the center lower panel. Confirm you can hear the sound of the door lock actuators when you press the sixth time.
    Transmitter Programming 22A-176
    Storing transmitter codes:
    The codes of up to three transmitters can be programmed into the keyless receiver unit memory. (If a fourth code is stored, the code that was programmed first will be erased.)
    NOTE: It is important to maintain the time limits between the steps. Make sure the doors and the tailgate are closed.
    1. Turn the ignition switch ON (II).
    2. Within 1 to 4 seconds, push the transmitter lock or unlock button.
    3. Within 1 to 4 seconds, turn the ignition switch OFF.
    4. Within 1 to 4 seconds, turn the ignition switch ON (II).
    5. Within 1 to 4 seconds, push the transmitter lock or unlock button.
    6. Within 1 to 4 seconds, turn the ignition switch OFF.
    7. Within 4 seconds, turn the ignition switch ON (II).
    8. Within 1 to 4 seconds, push the transmitter lock or unlock button.
    9. Within 1 to 4 seconds, turn the ignition switch OFF.
    10. Within 4 seconds, turn the ignition switch ON (II).
    11. Within 1 to 4 seconds, push the transmitter lock or unlock button.
    12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 seconds, push the transmitter lock or unlock button again.
    13. Within 10 seconds, press the transmitter lock or unlock buttons on the two additional transmitters. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
    14. Turn the ignition switch OFF, and remove the key.
    15. Confirm proper operation of the transmitters.
    Door Lock Switch Test 22A-177
    1. Remove the door panel (see page 20-9) .
    2. Remove the two mounting screws and the door lock switch.
    3. Check for continuity between the No. 1 and No. 2 terminals:
    4. There should be continuity when the door lock switch is in the LOCKED position.
    5. There should be no continuity when the door lock switch is in the UNLOCKED position.
    6. Check for continuity between the No. 2 and No. 3 terminals:
    7. There should be continuity when the door lock switch is in the UNLOCKED position.
    8. There should be no continuity when the door lock switch is in the LOCKED position.
    9. If the continuity is not as specified, replace the door lock switch.
    Tailgate Lock Actuator Test 22A-178
    1. Remove the tailgate lower trim panel (see page 20-80) .
    2. Disconnect the 2P connector from the actuator.
    3. Check actuator operation by connecting power and ground according to the table. To prevent damage to actuator, apply battery voltage only momentarily.
    4. If the actuator does not operate as specified, replace it.
    Hatch Glass Opener Actuator Test 22A-178
    3. Connect power to the No. 1 terminal and ground to the No. 2 terminals momentarily. The actuator should operate.
