Specifications02-1
Standards and Service Limits02-2 |
Cylinder Head02-3
Head Warpage ------ 0.05 mm (0.002 in.) Height 103.95 - 104.05 mm (4.093 - 4.096 in.) ------ Camshaft End play 0.05 - 0.20 mm (0.002 - 0.008 in.) 0.4 mm (0.02 in.) Camshaft-to-holder oil clearance No.1 journal 0.030 - 0.069 mm (0.001 - 0.003 in.) 0.15 mm (0.006 in.) No.2, 3, 4, 5 journals 0.060 - 0.099 mm (0.002 - 0.004 in.) 0.15 mm (0.006 in.) Total runout 0.03 mm (0.001 in.) max. 0.04 mm (0.002 in.) Cam lobe height Intake, primary 33.925 mm (1.3356 in.) ------ Intake, secondary 29.638 mm (1.1668 in.) ------ Exhaust 34.092 mm (1.3422 in.) ------ Valves Clearance (cold) Intake 0.21 - 0.25 mm (0.008 - 0.010 in.) ------ Exhaust 0.28 - 0.32 mm (0.011 - 0.013 in.) ------ Stem O.D. Intake 5.475 - 5.485 mm (0.2156 - 0.2159 in.) 5.445 mm (0.214 in.) Exhaust 5.450 - 5.460 mm (0.2146 - 0.2150 in.) 5.42 mm (0.213 in.) Stem-to-guide clearance Intake 0.030 - 0.055 mm (0.0012 - 0.0022 in.) 0.08 mm (0.003 in.) Exhaust 0.055 - 0.080 mm (0.0022 - 0.0031 in.) 0.11 mm (0.004 in.) Valve seats Width Intake 1.25 - 1.55 mm (0.049 - 0.061 in.) 2.00 mm (0.079 in.) Exhaust 1.25 - 1.55 mm (0.049 - 0.061 in.) 2.00 mm (0.079 in.) Stem installed height Intake 40.8 - 41.0 mm (1.606 - 1.614 in.) ------ Exhaust 54.6 - 54.8 mm (2.150 - 2.157 in.) ------ Valve springs Free length Intake 47.61 mm (1.874 in.) ------ Exhaust 49.64 mm (1.954 in.) 49.63 mm (1.954 in.) ------ Valve guides I.D. Intake 5.515 - 5.530 mm (0.2171 - 0.2177 in.) 5.55 mm (0.219 in.) Exhaust 5.515 - 5.530 mm (0.2171 - 0.2177 in.) 5.55 mm (0.219 in.) Installed height Intake 15.2 - 16.2 mm (0.598 - 0.638 in.) ------ Exhaust 15.5 - 16.5 mm (0.610 - 0.650 in.) ------ Rocker arms Arm-to-shaft clearance Intake 0.025 - 0.052 mm (0.0010 - 0.0020 in.) 0.08 mm (0.003 in.) Exhaust 0.018 - 0.056 mm (0.0007 - 0.0022 in.) 0.08 mm (0.003 in.)
Engine Block02-4
Block Warpage of deck 0.07 mm (0.003 in.) max. 0.10 mm (0.004 in.) Bore diameter (K20A4, K20A5 engines) A or l 86.010 - 86.020 mm (3.3862 - 3.3866 in.) 86.070 mm (3.3886 in.) B or ll 86.000 - 86.010 mm (3.3858 - 3.3862 in.) 86.070 mm (3.3886 in.) Bore diameter (K24A1 engines) A or l 87.010 - 87.020 mm (3.4256 - 3.4260 in.) 87.070 mm (3.4279 in.) B or lI 87.000 - 87.010 mm (3.4252 - 3.4256 in.) 87.070 mm (3.4279 in.) Bore taper ------ 0.05 mm (0.002 in.) Reboring limit ------ 0.25 mm (0.01 in.) Piston Skirt O.D. at 11 mm (0.4 in.) from bottom of skirt (K20A4, K20A5 engines) No letter or A 85.980 - 85.990 mm (3.3850 - 3.3854 in.) 85.930 mm (3.3831 in.) Letter B 85.970 - 85.980 mm (3.3846 - 3.3850 in.) 85.920 mm (3.3827 in.) Skirt O.D. at 13 mm (0.5 in.) from bottom of skirt (K24A1 engine) No letter or A 86.980 - 86.990 mm (3.4244 - v3.4248 in.) 86.930 mm (3.4224 in.) Letter B 86.970 - 86.980 mm (3.4240 - 3.4244 in.) 86.920 mm (3.4220 in.) Clearance in cylinder 0.020 - 0.040 mm (0.0008 - 0.0016 in.) 0.05 mm (0.002 in.) Ring groove width Top (K20A4, K20A5 engines) 1.220 - 1.230 mm (0.0481 - 0.0484 in.) 1.25 mm (0.049 in.) Top (K24A1 engine) 1.230 - 1.240 mm (0.0484 - 0.0488 in.) 1.26 mm (0.0450 in.) Second (K20A4, K20A5 engines) 1.220 - 1.230 mm (0.0481 - 0.0484 in.) 1.25 mm (0.049 in.) Second (K24A1 engine) 1.240 - 1.250 mm (0.0488 - 0.0492 in.) 1.270 mm (0.050 in.) Oil (K20A4, K24A1 engines) 2.005 - 2.025 mm (0.0789 - 0.0797 in.) 2.05 mm (0.081 in.) Oil (K20A5 engine) 2.805 - 2.825 mm (0.1104 - 0.1112 in.) 2.85 mm (0.112 in.) Piston ring Ring-to-groove clearance Top (K20A4 engine) 0.035 - 0.060 mm (0.0014 - 0.0024 in.) 0.13 mm (0.005 in.) Top (K20A5 engine) 0.030 - 0.055 mm (0.0012 - 0.0022 in.) 0.13 mm (0.005 in.) Top (K24A1 engine) 0.045 - 0.070 mm (0.0018 - 0.0028 in.) 0.13 mm (0.005 in.) Second (K20A4, K20A5 engines) 0.030 - 0.055 mm (0.0012 - 0.0022 in.) 0.13 mm (0.005 in.) Second (K24A1 engine) 0.050 - 0.075 mm (0.0020 - 0.0030 in.) 0.13 mm (0.005 in.) Ring end gap Top 0.20 - 0.35 mm (0.008 - 0.014 in.) 0.60 mm (0.024 in.) Second 0.40 - 0.55 mm (0.016 - 0.022 in.) 0.70 mm (0.028 in.) Oil (K20A4 (Except KY models) engine) 0.25 - 0.65 mm (0.010 - 0.026 in.) 0.75 mm (0.030 in.) Oil (K20A4 (KY model), K20A5, K24A1 engines) 0.20 - 0.70 mm (0.008 - 0.028 in.) 0.80 mm (0.031 in.) Piston pin O.D. 21.961 - 21.965 mm (0.8646 - 0.8648 in.) 21.953 mm (0.8643 in.) Pin-to-piston clearance -0.005- +0.002 mm (-0.00020- + 0.00008 in.) 0.005 mm (0.0002 in.) Connecting rod Pin-to-rod clearance 0.005 - 0.015 mm (0.0002 - 0.0006 in.) 0.02 mm (0.0008 in.) Small-end bore diameter 21.970 - 21.976 mm (0.8650 - 0.8652 in.) ------ Large-end bore diameter (Normal) K20A4, K20A5 engines 48.0 mm (1.89 in.) ------ K24A1 engine 51.0 mm (2.01 in.) ------ End play installed on crankshaft 0.15 - 0.30 mm (0.006 - 0.012 in.) 0.40 mm (0.016 in.)
02-5
Cooling02-6
Radiator Coolant capacity for K20A4 and K20A5 engines
(including engine, heater, hoses, and reservoir)M/T: engine overhaul 7.1 L (7.5 US qt, 6.2 Imp qt) M/T: coolant change 5.4 L (5.7 US qt, 4.8 Imp qt) A/T: engine overhaul 7.0 l (7.4 US qt, 6.2 lmp qt) A/T: coolant change 5.3 l (5.6 US qt, 4.7 lmp qt) Coolant capacity for K24A1 engine (includes engine, heater, hoses, and reservoir) M/T at engine overhaul 7.2 L (7.6 US qt, 6.3 Imp qt) M/T at coolant change 5.5 L (5.8 US qt, 4.8 Imp qt) A/T at engine overhaul 7.1 L (7.5 US qt, 6.2 Imp qt) A/T at coolant change 5.4 L (5.7 US qt, 4.8 Imp qt) Reservoir Coolant capacity 0.55 L (0.58 US qt, 0.48 Imp qt) Radiator cap Opening pressure 93 - 123 kPa (0.95 - 1.25 kgf/cm2, 14 - 18 psi) Thermostat Opening temperature Begins to open 76 - 80°C (169 - 176°F) Fully open 90°C (194°F) Valve lift at fully open 8.0 mm (0.31 in.) min. Radiator fan switch Switching temperature Turns ON 91 - 95°C (196 - 203°F) Turns OFF Subtract 3 - 8 °C (5 - 15 °F) from actual ON temperature
Manual Transmission and M/T Differential02-7
Transmission fluid Capacity 4WD at fluid change 1.9 L (2.0 US qt, 1.7 Imp qt) 4WD at overhaul 2.3 L (2.4 US qt, 2.0 Imp qt) 2WD at fluid change 1.9 L (2.0 US qt, 1.7 Imp qt) 2WD at overhaul 2.1 L (2.2 US qt, 1.8 Imp qt) Mainshaft End play 0.11 - 0.17 mm (0.004 - 0.007 in.) Adjust Diameter of bushing surface 20.80 - 20.85 mm (0.8189 - 0.8209 in.) 20.75 mm (0.817 in.) Diameter of distance collar 31.984 - 32.000 mm (1.2594 - 1.2598 in.) 31.93 mm (1.257 in.) Diameter of ball bearing contact area
(clutch housing side)27.977 - 27.990 mm (1.1015 - 1.1020 in.) 27.94 mm (1.100 in.) Diameter of needle bearing contact area 38.984 - 39.000 mm (1.5348 - 1.5354 in.) 38.93 mm (1.533 in.) Diameter of ball bearing contact area (transmission housing side) 27.987 - 28.000 mm (1.1019 - 1.1024 in.) 27.94 mm (1.100 in.) Runout 0.02 mm (0.001 in.) max. 0.05 mm (0.002 in.) Mainshaft 3rd, 4th and 5th gears I.D. 44.009 - 44.025 mm (1.7326 - 1.7333 in.) 44.08 mm (1.735 in.) End play 0.06 - 0.16 mm (0.002 - 0.006 in.) 0.25 mm (0.010 in.) Thickness 23.92 - 23.97 mm (0.981 - 0.944 in.) 23.80 mm (0.937 in.) Countershaft Diameter of needle bearing contact area (clutch housing side) Diameter of distance collar contact area 35.000 - 35.015 mm (1.3780 - 1.3785 in.) 34.95 mm (1.376 in.) 39.937 - 39.950 mm (1.5723 - 1.5728 in.) 39.88 mm (1.570 in.) Diameter of ball bearing contact area (transmission housing side) 30.020 - 30.033 mm (1.1819 - 1.1824 in.) 29.97 mm (1.180 in.) Run out 0.02 mm (0.001 in.) max. 0.05 mm (0.002 in.) 35 mm shim-to-bearing inner race clearance 0.04 - 0.10 mm (0.0016 - 0.0039 in.) Adjust Countershaft 1st gear I.D. 52.010 - 52.029 mm (2.0476 - 2.0484 in.) 52.08 mm (2.050 in.) End play 0.06 - 0.16 mm (0.002 - 0.006 in.) 0.25 mm (0.010 in.) Thickness 22.92 - 22.97 mm (0.902 - 0.904 in.) 22.87 mm (0.900 in.) Countershaft 2nd gear I.D. 52.010 - 52.029 mm (2.0476 - 2.0484 in.) 52.08 mm (2.050 in.) End play 0.06 - 0.16 mm (0.002 - 0.006 in.) 0.25 mm (0.010 in.) Thickness 27.92 - 27.97 mm (1.099 - 1.101 in.) 27.87 mm (1.097 in.) Countershaft 1st gear distance collar I.D. 39.95 - 39.96 mm (1.5728 - 1.5732 in.) 39.97 mm (1.574 in.) O.D. 46.989 - 47.000 mm (1.8499 - 1.8504 in.) 46.94 mm (1.848 in.) Length 23.03 - 23.08 mm (0.907 - 0.909 in.) ------ Countershaft 2nd gear distance collar I.D. 39.95 - 39.96 mm (1.5728 - 1.5732 in.) 39.97 mm (1.574 in.) O.D. 46.989 - 47.000 mm (1.8499 - 1.8504 in.) 46.94 mm (1.848 in.) Length 28.03 - 28.08 mm (1.104 - 1.106 in.) ------ Mainshaft 4th and 5th gears distance collar I.D. 32.00 - 32.01 mm (1.2598 - 1.2602 in.) 32.02 mm (1.261 in.) O.D. 38.989 - 39.000 mm (1.5350 - 1.5354 in.) 38.94 mm (1.533 in.) Length
A 51.95 - 52.05 mm (2.045 - 2.049 in.) ------ B 24.03 - 24.08 mm (0.946 - 0.947 in.) ------ MBS distance collar I.D. 28.00 - 28.01 mm (1.102 - 1.103 in.) 28.02 mm (1.103 in.) Length 23.95 - 24.05 mm (0.943 - 0.947 in.) ------
Manual Transmission and M/T Differential (cont'd)02-8
Reverse idler gear I.D. 20.016 - 20.043 mm (0.7880 - 0.7891 in.) 20.90 mm (0.832 in.) Gear-to-reverse gear shaft clearance 0.036 - 0.084 mm (0.0014 - 0.0033 in.) 0.16 mm (0.006 in.) Synchro ring Ring-to-gear clearance Ring pushed against gear 0.70 - 1.49 mm (0.028 - 0.059 in.) 0.4 mm (0.016 in.) Double cone synchro Outer synchro ring-to- synchro cone clearance Ring pushed against gear 0.70 - 1.19 mm (0.028 - 0.047 in.) 0.3 mm (0.012 in.) Synchro cone-to-gear clearance Ring pushed against gear 0.50 - 1.04 mm (0.020 - 0.041 in.) 0.3 mm (0.012 in.) Outer synchro ring-to- gear cone clearance Ring pushed against gear 0.95 - 1.68 mm (0.037 - 0.066 in.) 0.6 mm (0.024 in.) Triple cone synchro Outer synchro ring-to- synchro cone clearance Ring pushed against gear 0.70 - 1.19 mm (0.028 - 0.047 in.) 0.3 mm (0.012 in.) Synchro cone-to-gear clearance Ring pushed against gear 0.50 - 1.04 mm (0.020 - 0.041 in.) 0.3 mm (0.012 in.) Outer synchro ring-to- gear cone clearance Ring pushed against gear 0.95 - 1.68 mm (0.037 - 0.066 in.) 0.6 mm (0.024 in.) Shift fork Finger thickness 7.4 - 7.6 mm (0.29 - 0.30 in.) ------ Fork-to-synchro sleeve clearance 0.35 - 0.65 mm (0.014 - 0.026 in.) 1.0 mm (0.039 in.) Reverse shift fork Finger thinkness 13.4 - 13.7 mm (0.527 - 0.539 in.) ------ Fork-to-reverse idler gear clearance 0.20 - 0.59 mm (0.007 - 0.024 in.) 1.2 mm (0.047 in.) Shift arm I.D. 13.973 - 14.000 mm (0.5501 - 0.5512 in.) ------ Shift fork diameter at contact area 16.9 - 17.0 mm (0.665 - 0.669 in.) ------ Shift arm-to-shift lever clearance 0.2 - 0.5 mm (0.008 - 0.020 in.) 0.60 mm (0.023 in.) Select lever Finger width 14.85 - 14.95 mm (0.585 - 0.589 in.) ------ Shift lever Shaft-to-select lever clearance 0.05 - 0.25 mm (0.002 - 0.010 in.) 0.50 mm (0.020 in.) Groove (to select lever) 15.00 - 15.10 mm (0.591 - 0.594 in.) ------ Shaft-to-shift arm clearance 0.013 - 0.07 mm (0.0005 - 0.003 in.) 0.1 mm (0.004 in.) M/T differential carrier Pinion shaft contact area I.D. 18.010 - 18.028 mm (0.7091 - 0.7098 in.) ------ Carrier-to-pinion shaft clearance 0.027 - 0.057 mm (0.0011 - 0.0022 in.) 0.1 mm (0.004 in.) Driveshaft contact area I.D. 28.025 - 28.045 mm (1.1033 - 1.1041 in.) ------ M/T differential pinion gear Backlash 0.05 - 0.15 mm (0.002 - 0.006 in.) ------ I.D. 18.042 - 18.066 mm (0.7103 - 0.7113 in.) ------ Pinion gear-to-pinion shaft clearance 0.059 - 0.095 mm (0.0023 - 0.0037 in.) 0.15 mm (0.006 in.) 80 mm shim 80 mm shim-to-bearing outer race clearance in transmission housing 0 - 0.10 mm (0 - 0.0039 in.) Adjust Transfer Diameter of tapered roller bearing contact area (transfer shaft) 24.975 - 24.990 mm (0.9833 - 0.9838 in.) 24.92 mm (0.9811 in.) Diameter of tapered roller bearing contact area (transfer drive gear) 40.002 - 40.018 mm (1.5749 - 1.5755 in.) 38.95 mm (1.5335 in.) Diameter of tapered roller bearing contact area (driven gear side) 35.002 - 35.018 mm (1.3780 - 1.3786 in.) 34.95 mm (1.3760 in.) Diameter of tapered roller bearing contact area (splined side) 26.975 - 26.988 mm (1.0620 - 1.0625 in.) 26.92 mm (1.0598 in.) Transfer gear backlash 0.06 - 0.16 mm (0.0024 - 0.0063 in.) Adjust Total starting torque 2.24 - 3.71 N·m (22.0 - 36.4 kgf·cm, 19.1 - 31.6 lbf·in) Adjust
Automatic Transmission and A/T Differential02-9
ATF (Automatic Transmission Fluid) Capacity Use Genuine Honda ATF- Z1 4WD at fluid change 3.1 L (3.3 US qt, 2.7 Imp qt) 2WD at fluid change 2.9 L (3.1 US qt, 2.6 Imp qt) 4WD at overhaul 7.2 L (7.6 US qt, 6.3 Imp qt) 2WD at overhaul 6.5 L (6.9 US qt, 5.7 Imp qt) ATF pressure Line pressure at 2,000 rpm (min-1) in [P] or [N] position 900 - 960 kPa
(9.2 - 9.8 kgf/cm2, 130 - 140 psi)850 kPa
(8.7 kgf/cm2, 120 psi)1st clutch pressure at 2,000 rpm (min-1) in 1st gear in [1] position 890 - 970 kPa
(9.1 - 9.9 kgf/cm2, 130 - 140 psi)840 kPa
(8.6 kgf/cm2, 120 psi)2nd clutch pressure at 2,000 rpm (min-1) in 2nd gear in [2] position 890 - 970 kPa
(8.6 kgf/cm2, 120 psi)3rd clutch pressure at 2,000 rpm (min-1) in 3rd gear in [D] position 890 - 970 kPa
(8.6 kgf/cm2, 120 psi)4th clutch pressure at 2,000 rpm (min-1) in 4th gear in [D] position 890 - 970 kPa
(8.6 kgf/cm2, 120 psi)Torque converter Stall speed
Check with vehicle on level ground2,320 rpm (min-1) 2,170 - 2,470 rpm
(min-1)Clutch
K20A4 and K20A5 engine modelsClutch end plate-to-top disc clearance 1st ------ 1.23 - 1.43 mm
(0.048 - 0.056 in.)2nd ------ 0.75 - 0.95 mm
(0.030 - 0.037 in.)3rd and 4th ------ 0.73 - 0.93 mm
(0.029 - 0.037 in.)Clutch return spring free length 1st and 2nd 50.8 mm (2.00 in.) 48.8 mm (1.92 in.) 3rd and 4th 33.5 mm (1.32 in.) 31.5 mm (1.24 in.) Clutch disc thickness 1.94 mm (0.076 in.) ------ Clutch plate thickness 2.00 mm (0.079 in.) When discolored Clutch waved-plate phase difference 0.07 - 0.20 mm (0.003 - 0.008 in.) 0.05 mm (0.002 in) 1st Clutch end plate thickness Mark 1 2.3 mm (0.091 in.) When discolored Mark 2 2.4 mm (0.094 in.) When discolored Mark 3 2.5 mm (0.098 in.) When discolored Mark 4 2.6 mm (0.102 in.) When discolored Mark 5 2.7 mm (0.106 in.) When discolored Mark 6 2.8 mm (0.110 in.) When discolored Mark 7 2.9 mm (0.114 in.) When discolored Mark 8 3.0 mm (0.118 in.) When discolored Mark 9 3.1 mm (0.122 in.) When discolored Mark 10 3.2 mm (0.126 in.) When discolored Mark 11 3.3 mm (0.130 in.) When discolored Mark 12 3.4 mm (0.134 in.) When discolored 2nd clutch end plate thickness Mark 1 2.6 mm (0.102 in.) When discolored Mark 2 2.7 mm (0.106 in.) When discolored Mark 3 2.8 mm (0.110 in.) When discolored Mark 4 2.9 mm (0.114 in.) When discolored Mark 5 3.0 mm (0.118 in.) When discolored Mark 6 3.1 mm (0.122 in.) When discolored Mark 7 3.2 mm (0.126 in.) When discolored Mark 8 3.3 mm (0.130 in.) When discolored Mark 9 3.4 mm (0.134 in.) When discolored
Automatic Transmission and A/T Differential (cont'd)02-10
Clutch K20A4 and K20A5 engine models (cont'd) 3rd and 4th clutch end plate thickness Mark 11 3.1 mm (0.122 in.) When discolored Mark 12 3.2 mm (0.126 in.) When discolored Mark 13 3.3 mm (0.130 in.) When discolored Mark 14 3.4 mm (0.134 in.) When discolored Mark 15 3.5 mm (0.138 in.) When discolored Mark 16 3.6 mm (0.142 in.) When discolored Mark 17 3.7 mm (0.146 in.) When discolored Mark 18 3.8 mm (0.150 in.) When discolored Mark 19 3.9 mm (0.154 in.) When discolored Clutch
K24A1 engine modelClutch end plate-to-top disc clearance 1st ------ 1.28 - 1.48 mm (0.050 - 0.058 in.) 2nd ------ 0.85 - 1.05 mm (0.033 - 0.041 in.) 3rd and 4th ------ 0.73 - 0.93 mm (0.029 - 0.037 in.) Clutch return spring free length 1st and 2nd 50.8 mm (2.00 in.) 48.8 mm (1.92 in.) 3rd and 4th 33.5 mm (1.32 in.) 31.5 mm (1.24 in.) Clutch disc thickness 1.94 mm (0.076 in.) ------ Clutch plate thickness 1st 1.6 mm (0.063 in.) When discolored 2nd 2.0 mm (0.079 in.) When discolored 3rd and 4th 2.3 mm (0.091 in.) When discolored Clutch waved-plate phase difference 0.07 - 0.20 mm (0.003 - 0.008 in.) 0.05 mm (0.002 in) 1st Clutch end plate thickness Mark 1 2.6 mm (0.102 in.) When discolored Mark 2 2.7 mm (0.106 in.) When discolored Mark 3 2.8 mm (0.110 in.) When discolored Mark 4 2.9 mm (0.114 in.) When discolored Mark 5 3.0 mm (0.118 in.) When discolored Mark 6 3.1 mm (0.122 in.) When discolored Mark 7 3.2 mm (0.126 in.) When discolored Mark 8 3.3 mm (0.130 in.) When discolored Mark 9 3.4 mm (0.134 in.) When discolored 2nd clutch end plate thickness Mark 1 2.6 mm (0.102 in.) When discolored Mark 2 2.7 mm (0.106 in.) When discolored Mark 3 2.8 mm (0.110 in.) When discolored Mark 4 2.9 mm (0.114 in.) When discolored Mark 5 3.0 mm (0.118 in.) When discolored Mark 6 3.1 mm (0.122 in.) When discolored Mark 7 3.2 mm (0.126 in.) When discolored Mark 8 3.3 mm (0.130 in.) When discolored Mark 9 3.4 mm (0.134 in.) When discolored 3rd and 4th clutch end plate thickness Mark 1 2.1 mm (0.083 in.) When discolored Mark 2 2.2 mm (0.087 in.) When discolored Mark 3 2.3 mm (0.091 in.) When discolored Mark 4 2.4 mm (0.094 in.) When discolored Mark 5 2.5 mm (0.098 in.) When discolored Mark 6 2.6 mm (0.102 in.) When discolored Mark 7 2.7 mm (0.106 in.) When discolored Mark 8 2.8 mm (0.110 in.) When discolored Mark 9 2.9 mm (0.114 in.) When discolored
02-11
Mainshaft Diameter of needle bearing contact area at stator shaft 22.984 - 23.000 mm (0.905 - 0.906 in.) When worn or damaged at 3rd gear 51.975 - 51.991 mm (2.046 - 2.047 in.) When worn or damaged at 4th gear collar 33.975 - 33.991 mm (1.3376 - 1.3382 in.) When worn or damaged I.D. of gears 3rd gear 57.000 - 57.019 mm
(2.2441 - 2.2448 in.)When worn or damaged 4th gear 40.000 - 40.016 mm
(1.5748 - 1.5754 in.)When worn or damaged End play of gears 3rd gear 0.03 - 0.31 mm (0.001 - 0.012 in.) ------ 4th gear 0.1 - 0.212 mm (0.004-0.008 in.) ------ 41 x 68 mm thrust washer thickness No. 1 6.35 mm (0.250 in.) When worn or damaged No. 2 6.40 mm (0.252 in.) When worn or damaged No. 3 6.45 mm (0.254 in.) When worn or damaged No. 4 6.50 mm (0.256 in.) When worn or damaged No. 5 6.55 mm (0.258 in.) When worn or damaged No. 6 6.60 mm (0.260 in.) When worn or damaged 4th gear collar length 66.3 - 66.4 mm (2.610 - 2.614 in.) ------ Length of 4th gear collar flange from end 19.15 - 19.30 mm (0.754 - 0.760 in.) When worn or damaged Sealing ring thickness 1.91 - 1.97 mm (0.0752 - 0.0776 in.) 1.86 (0.0732 in.) Width of sealing ring
groove2.025 - 2.060 mm
(0.0797 - 0.0811 in.)2.080 mm (0.0819 in.) Clutch feed pipe O.D. 7.97 - 7.98 mm (0.3138 - 0.3142 in.) 7.95 mm (0.313 in.) Clutch feed pipe bushing I.D. 8.000 - 8.015 mm
(0.3150 - 0.3156 in.)8.030 mm (0.3161 in.) Countershaft Diameter of needle bearing contact area at torque converter housing 36.005-36.015 mm
(1.4175 - 1.4179 in.)When worn or damaged at 4th gear collar 37.982 - 37.996 mm
(1.4954 - 1.4959 in.)When worn or damaged at reverse gear collar 39.979 - 40.000 mm (1.5740 - 1.5748 in.) When worn or damaged I.D. of gears 4th gear 43.000 - 43.016 mm
(1.6929 - 1.6935 in.)When worn or damaged Reverse gear 46.000 - 46.016 mm (1.8110 - 1.8116 in.) When worn or damaged End play of gears 1st gear 0.10 - 0.42 mm (0.004 - 0.017 in.) ------ 2nd gear 0.10 - 0.42 mm (0.004 - 0.017 in.) ------ 3rd gear 0.10 - 0.42 mm (0.004 - 0.017 in.) ------ 4th gear 0.1 - 0.2 mm (0.004 - 0.008 in.) ------ Reverse gear 0.10 - 0.25 mm (0.004 - 0.010 in.) ------ 4th gear collar length 24.00 - 24.05 mm (0.945 - 0.947 in.) ------ Distance collar length 74.25 - 74.30 mm (2.923 - 2.925 in.) ------ Reverse selector hub width 25.45 - 25.65 mm (1.002 - 1.010 in.) ------ Reverse selector hub O.D. 55.87 - 55.90 mm (2.200 - 2.201 in.) When worn or damaged
Automatic Transmission and A/T Differential (cont'd)02-12
Secondary shaft Diameter of needle bearing contact area at 1st gear 39.986 - 39.999 mm
(1.5742 - 1.5748 in.)When worn or damaged at 2nd gear 39.986 - 39.999 mm (1.5742 - 1.5748 in.) When worn or damaged I.D. of gears 1st gear 47.000 - 47.016 mm
(1.8504 - 1.8510 in.)When worn or damaged 2nd gear 46.000 - 46.016 mm
(1.8110 - 1.8116 in.)When worn or damaged End play of gears 1st gear 0.07 - 0.15 mm (0.003 - 0.006 in.) ------ 2nd gear 0.04 - 0.12 mm (0.002 - 0.005 in.) ------ 37 x 58 mm thrust washer thickness No. 1 3.900 mm (0.154 in.) When worn or damaged No. 2 3.925 mm (0.155 in.) When worn or damaged No. 3 3.950 mm (0.156 in.) When worn or damaged No. 4 3.975 mm (0.156 in.) When worn or damaged No. 5 4.000 mm (0.157 in.) When worn or damaged No. 6 4.025 mm (0.158 in.) When worn or damaged No. 7 4.050 mm (0.159 in.) When worn or damaged No. 8 4.075 mm (0.160 in.) When worn or damaged No. 9 4.100 mm (0.161 in.) When worn or damaged No. 10 4.125 mm (0.162 in.) When worn or damaged No. 11 4.150 mm (0.163 in.) When worn or damaged No. 12 4.175 mm (0.164 in.) When worn or damaged No. 13 4.200 mm (0.165 in.) When worn or damaged No. 14 4.225 mm (0.166 in.) When worn or damaged No. 15 4.250 mm (0.167 in.) When worn or damaged No. 16 4.275 mm (0.168 in.) When worn or damaged No. 17 4.300 mm (0.169 in.) When worn or damaged No. 18 4.325 mm (0.170 in.) When worn or damaged No. 19 4.350 mm (0.171 in.) When worn or damaged No. 20 4.375 mm (0.172 in.) When worn or damaged 40 x 51.5 mm thrust washer thickness No. 1 4.80 mm (0.189 in.) When worn or damaged No. 2 4.85 mm (0.191 in.) When worn or damaged No. 3 4.90 mm (0.193 in.) When worn or damaged No. 4 4.95 mm (0.195 in.) When worn or damaged No. 5 5.00 mm (0.197 in.) When worn or damaged No. 6 5.05 mm (0.199 in.) When worn or damaged 27 x 45 x 44 mm collar length 43.9 - 44.0 mm (1.728 - 1.732 in.) ------ Sealing ring thickness 1.91 - 1.97 mm (0.0752 - 0.0776 in.) 1.86 (0.0732 in.) Width of sealing ring groove 2.025 - 2.060 mm (0.0797 - 0.0811 in.) 2.080 mm (0.0819 in.) Clutch feed pipe O.D. 7.97 - 7.98 mm
(0.3138 - 0.3142 in.)7.95 mm
(0.3130 in.)Clutch feed pipe bushing O.D. 8.000 - 8.015 mm
(0.3161 in.)ATF guide of sealing ring contact I.D. 29.000 - 29.021 mm
(1.1417 - 1.1426 in.)29.05 mm (1.144 in.)
02-13
Idler gear shaft Diameter of needle bearing contact area End cover side 32.003 - 32.013 mm (1.2600 - 1.2604 in.) When worn or damaged Thickness of cotters 1.39 - 1.42 mm (0.0547 - 0.0559 in.) ------ Reverse idler gear Reverse idler gear shaft diameter at needle bearing contact area 14.99 - 15.00 mm (0.5902 - 0.5906 in.) When worn or damaged I.D. 20.007 - 20.020 mm
(0.7877 - 0.7882 in.)When worn or damaged I.D. of reverse idler gear shaft contact area on transmission housing 14.800 - 14.818 mm (0.5827 - 0.5834 in.) ------ I.D. of reverse idler gear shaft holder 14.800 - 14.824 mm (0.5827 - 0.5836 in.) When worn or damaged ATF pump ATF pump thrust clearance 0.03 - 0.05 mm (0.001 - 0.002 in.) 0.07 mm (0.003 in.) ATF pump gear-to-body clearance Drive gear 0.210 - 0.265 mm
(0.08 - 0.010 in.)------ Driven gear 0.070 - 0.125 mm (0.003 - 0.005 in.) ------ ATF pump driven gear I.D. 14.016 - 14.034 mm (0.5518 - 0.5525 in.) When worn or damaged ATF pump driven gear shaft O.D. 13.980 - 13.990 mm (0.5504 - 0.5508 in.) When worn or damaged Stator shaft Needle bearing contact I.D. Torque converter side 27.000 - 27.021 mm (1.063 - 1.064 in.) When worn or damaged ATF pump side 29.000 - 29.021 mm
(1.1417 - 1.1426 in.)------ Sealing ring contact area I.D. 29.000 - 29.021 mm
(1.1417 - 1.1426 in.)29.05 mm (1.144 in.) Reverse shift fork Fork finger thickness 5.90 - 6.00 mm (0.232 - 0.236 in.) 5.40 mm (0.213 in.) Park gear and pawl ------ When worn or damaged Servo body Shift fork shaft bore I.D. 14.000 - 14.010 mm
(0.5512 - 0.5516 in.)------ Shift fork shaft valve bore I.D. 37.000 - 37.039 mm (1.4567 - 1.4582 in.) 37.045 mm (1.4585 in.) Regulator valve body Sealing ring contact I.D. 29.000 - 29.021 mm (1.1417 - 1.1426 in.) 29.05 mm (1.144 in.)
Main valve body springs (see page 14- 209) Shift valve A spring 0.8 mm
(0.031 in.)5.6 mm
(0.220 in.)28.1 mm
(1.106 in.)15.9 Shift valve B spring 0.8 mm
(0.031 in.)5.6 mm
(0.220 in.)28.1 mm
(1.106 in.)15.9 Shift valve C spring 0.8 mm
(0.031 in.)5.6 mm
(0.220 in.)28.1 mm
(1.106 in.)15.9 Relief valve spring 1.0 mm
(0.039 in.)9.6 mm
(0.378 in.)34.1 mm
(1.343 in.)10.2 Lock-up control valve spring 0.65 mm
(0.026 in.)7.1 mm
(0.280 in.)23.1 mm
(0.909 in.)12.7 Cooler check valve spring 0.9 mm
(0.035 in.)6.6 mm
(0.260 in.)26.5 mm
(1.043 in.)12.6 Servo control valve spring 0.7 mm
(0.028 in.)6.6 mm
(0.260 in.)35.7 mm (1.406 in.) 17.2 Shift valve E spring 0.8 mm
(0.031 in.)5.6 mm
(0.220 in.)28.1 mm
(1.106 in.)15.9
Automatic Transmission and A/T Differential (cont'd)02-14
Regulator valve body springs (see page 14- 211) Stator reaction spring 4.5 mm
(0.177 in.)35.4 mm
(1.394 in.)30.3 mm
(1.193 in.)1.92 Regulator valve spring A 1.9 mm
(0.075 in.)14.7 mm
(0.579 in.)80.6 mm
(3.173 in.)16.1 Regulator valve spring B 1.6 mm
(0.063 in.)9.2 mm
(0.362 in.)44.0 mm
(1.732 in.)12.5 Torque converter check valve spring 1.2 mm
(0.047 in.)8.6 mm
(0.339 in.)33.8 mm
(1.331 in.)12.2 Lock-up shift valve spring 1.0 mm
(0.039 in.)6.6 mm
(0.260 in.)35.5 mm
(1.398 in.)18.2 3rd accumulator spring 2.5 mm
(0.098 in.)14.6 mm
(0.575 in.)29.9 mm
(1.177 in.)4.9 1st accumulator spring A 2.4 mm
(0.094 in.)18.6 mm
(0.732 in.)49.0 mm
(1.929 in.)7.1 1st accumulator spring B 2.3 mm
(0.091 in.)12.2 mm
(0.480 in.)31.5 mm
(1.240 in.)6.6 Servo body springs (see page 14-212) CPB valve spring 0.7 mm
(0.028 in.)9.1 mm
(0.358 in.)32.3 mm
(1.272 in.)8.6 4th accumulator spring B 2.3 mm
(0.091 in.)12.2 mm
(0.480 in.)31.5 mm
(1.240 in.)6.6 4th accumulator spring A 2.4 mm
(0.094 in.)18.6 mm
(0.732 in.)49.0 mm
(1.929 in.)7.1 2nd accumulator spring B 2.0 mm
(0.079 in.)10.6 mm
(0.417 in.)34.0 mm
(1.339 in.)8.0 2nd accumulator spring A 2.2 mm
(0.087 in.)16.6 mm
(0.654 in.)48.2 mm
(1.898 in.)8.5 3th accumulator spring 2.5 mm
(0.098 in.)14.6 mm
(0.575 in.)29.9 mm
(1.177 in.)4.9
Automatic Transmission and A/T Differential (cont'd)02-15
Transfer (4WD) Diameter of transfer shaft on bearing contact area at roller bearing 38.485 - 38.500 mm
(1.5152 - 1.5157 in.)38.43 mm (1.513 in.) at tapered roller bearing 24.975 - 24.990 mm (0.9833 - 0.9839 in.) 24.92 mm (0.9811 in.) Transfer drive gear diameter at tapered roller bearing 40.002 - 40.018 mm (1.5749 - 1.5755 in.) 38.95 mm (1.533 in.) Diameter of transfer driven gear on tapered roller bearing contact area at driven gear side 35.002 - 35.018 mm (1.3780 - 1.3787 in.) 34.95 mm (1.376 in.) at shaft splines side 26.975 - 26.988 mm (1.0620 - 1.0625 in.) 26.92 mm (1.060 in.) Transfer gear backlash 0.06 - 0.16 mm (0.002 - 0.006 in.) Adjust Total starting torque (Preload) 2.16 - 3.57 N·m (22.0 - 36.4 kgf·cm, 19.2 - 31.6 lbf·in) Adjust
Rear Differential
Differential fluid Capacity Use genuine Honda DPSF at fluid change 1.0 L (1.1 US qt, 0.9 Imp qt) at overhaul 1.2 L (1.3 US qt, 1.1 Imp qt)
Brakes02-16
Parking brake lever Distance travelled when lever pulled with 196 N (20 kgf, 44 lbs) of force 5 - 9 clicks Brake pedal Pedal height (carpet removed) 173 mm (6 13/16 in.) Free play 1 - 5 mm (0.04 - 0.2 in.) Master cylinder Piston-to-pushrod clearance 0 - 0.4 mm (0 - 0.02 in.) Brake disc Disc thickness Front 23.0 mm (0.91 in.) 21.0 mm (0.83 in.) Rear 9.0 mm (0.35 in.) 7.0 mm (0.28 in.) Disc runout Front and rear ------ 0.10 mm (0.004 in.) Disc parallelism Front and rear ------ 0.015 mm (0.0006 in.) Pad thickness Front 11.0 mm (0.43 in.) 1.6 mm (0.06 in.) Rear 9.0 mm (0.35 in.) 1.0 mm (0.04 in.) Rear parking brake Brake drum I.D. Brake shoe lining thickness 170 mm (6.69 in.) 171 mm (6.73 in.) 3.2 mm (0.13 in.) 1.0 mm (0.04 in.) Brake booster Master cylinder fluid pressure with pressing brake pedal with 98 N (10 kgf, 22 lbs) at 0 kPa (0 mmHg, 0 in.Hg) of vacuum 1,040 kPa (10.8 kgf/cm2, 151 psi) at 40.0 kPa (300 mmHg, 11.8 in.Hg) of vacuum 7,129 kPa (72.7 kgf/cm2, 1,030 psi) at 66.7 kPa (500 mmHg, 19.7 in.Hg) of vacuum 11,248 kPa (114.7 kgf/cm2, 1,631 psi)
Specifications02-1
