Rear Differential15-1
Differential Removal15-14 |
- Drain the differential fluid (see page 15-13) .
- Mark the propeller shaft (A) and companion flange of the rear differential assembly (B) so they can be reinstalled in their original positions (C).
- Remove the propeller shaft from the rear differential assembly.
- Remove the EVAP canister assembly with bracket (see page 11-199) .
- Remove the rear differential damper (A).
- Place a transmission jack under the rear differential assembly, then remove the right mounting bracket B (B) and the left mounting bracket B (B).
- Remove the mounting bolts and the plate.
- Remove the breather tube (A) from the breather tube fitting.
- Lower the rear differential assembly while pulling both driveshaft inner joints out of the rear differential assembly.
- NOTE: Be careful not to damage the driveshaft ring (B) when prying out the differential inboard joints.
- Remove the rear differential mount assembly A (A) from the rear differential assembly (B).
