Maintenance03-1
 Maintenance Schedule for Normal Conditions03-4  |
(European Model)
Listed by Maintenance Item
Follow the Normal Conditions Maintenance Schedule if the severe driving conditions specified in the Severe Conditions Maintenance Schedule (see page 03-6) do not apply.
Service at the indicated distance or time whichever comes first. km x 1,000 20 40 60 80 100 120 140 160 180 200 miles x 1,000 12 24 36 48 60 72 84 96 108 120 months 12 24 36 48 60 72 84 96 108 120 Replace engine oil (see page 08-5) ![]()
Replace engine oil filter (see page 08-6) ![]()
Inspect front and rear brakes Check the brake pad and disc thickness. Check for damage or cracks (see page 19A-12) , (see page 19A-18) , (see page 19A-30) ,
(see page 19A-32) .Check the brake linings for cracking, grazing, wear and contamination (see page 19A-39) . Check the calipers for damage, leaks, and tightness
(see page 19A-3) .![]()
Check parking brake adjustment (see page 19A-6) . ![]()
Check lights alignment Check the position of the headlights (see page 22A-96) . ![]()
Test drive (noise, stability dashboard operation) Check for road stability, noise, vibration and dashboard operation. ![]()
Visually inspect the following items: Check for correct installation and position, check for cracks, deterioration, rust, and leaks. Check tightness of screws, nuts, and joints. If necessary, retighten. Tie rod ends, steering gearbox, and boots Check rack grease and steering linkage. Check the boot for damage and leaking grease (see page 17-8) . ![]()
Suspension components Check the bolts for tightness. Check all dust cover for deterioration and damage. (see page 18-2) . Driveshaft boots Check the boot and boot band for cracks. Check rack grease. (see page 16-3) . Brake hoses and lines (including ABS) Check the master cylinder, proportioning control valve and ABS modulator and leakage (see page 19B-36) . All fluid levels and condition of fluids Check levels and check for leaks. If necessary, add engine coolant (see page 10-6) , MTF (see page 13-4) , ATF (see page 14-131) , DPSF (4WD) (see page 15-13) . brake fluid (see page 19A-9) , windshield fluid, and battery fluid. Exhaust system Check the exhaust pipe and muffler for damage, leaks and tightness (see page 09-9) . Fuel lines and connections Check fuel lines for loose connections, cracks and deterioration. Retighten loose connections and replace any damaged parts (see page 11-155) . Tyre condition Check for pressure, puncture, cuts, and irregular thread wear.
03-5
Service at the indicated distance or time whichever comes first. km x 1,000 20 40 60 80 100 120 140 160 180 200 miles x 1,000 12 24 36 48 60 72 84 96 108 120 months 12 24 36 48 60 72 84 96 108 120 Replace air cleaner element (see page 11-182) . Every 40,000 km (24,000 miles) Replace spark plugs (see page 04-23) . Inspect valve clearance (see page 06-9) . Inspect and adjust drive belts Check for cracks, damage, deflection and tension (see page 04-29) . ![]()
Replace dust and pollen filter (see page 21-25) . Every 30,000 km (18,000 miles) or 1 year Replace fuel filter (see page 11-166) . ![]()
Inspect idle speed (see page 11-148) . ![]()
Replace manual transmission fluid Use genuine Honda Manual Transmission Fluid (MTF)
(see page 13-4) .Every 120,000 km (72,000 miles) or 8 years Replace automatic transmission fluid Use genuine Honda ATF-Z1 (see page 14-131) . At 120,000 km (72,000 miles) or 8 years, then replace every 80,000 km (48,000 miles) or 4 years Replace rear differential fluid (4WD model) Use genuine Honda DPSF (see page 15-13) . At 120,000 km (72,000 miles) or 8 years, then replace every 60,000 km (36,000 miles) or 4 years Replace engine coolant Use Honda All Season Antifreeze/Coolant Type 2 (see page 10-6) . At 200,000 km (120,000 miles) or 10 years, then replace every 100,000 km (60,000 miles) or 5 years Replace brake fluid Use only DOT 3 or DOT 4 brake fluid. We recommend Genuine Honda Brake Fluid. Check that brake fluid level between the upper and lower marks on the reservoir (see page 19A-9) . Every 3 years
Maintenance03-1
