Honda CR-V Body Repair0-1
Table of Contents 0-3 |
Table of Contents
Index
General Information
Supplemental Restraint System (SRS)
SRS Component Replacement / Inspection After Deployment
Identification Number Locations
Lift and Support Points
Frame Hoist
Safety Stands
Floor Jack
Body Specifications / Wheel Alignment
Exterior Parts Removal / Installation
Tailgate Compartment Parts Removal / Installation
Body Construction
Door and Bumper Reinforcement Beams
Zinc-plated Steel Plate Repair
Color Chart Paint Specifications
Types and Materials of Exterior Plastic Parts
Preparation of Work
Outline of Body Repair
General Safety Precaution
Accurate Inspection of Damaged Parts (Visual)
Description
Measurement
Reshaping
Correction of the Damaged Area
Replacement
Removal
Installation
Rust Prevention / Paint
Installation and Inspection
Repair Tools
Measurement Equipment
Protective Tools
Processing Tools
Cutting Tools
Shaping Tools
Fixing Tools
Welders
Sanding Tools
Welding Methods
Spot Welding
Carbon Dioxide Arc Welder (MIG Arc Weld)
Gas Welding
Replacement
Front Bulkhead
Mass Production Body Welding Diagram
Removal
Installation
Front Wheelhouse / Damper Housing
Removal
Installation
Front Side Frame / Outrigger
Removal
Installation
Front Pillar Outer Panel
Removal
Installation
Side Sill Outer Panel
Removal
Installation
Roof Panel
Removal
Installation
Rear Side Outer Panel
Mass Production body Welding Diagram
Removal
Installation
Rear Panel
Removal
Installation
Rear Floor / Rear Floor Cross-member
Removal
Installation
Body Dimensional Drawings
Upper Body Measuring Dimensions
Engine Compartment
Engine / Transmission Mount Positions
Passenger's Compartment
Rear Panel / Rear Pillar Gutter Positions
Tailgate Hinge Mount Position
Opening Repair Chart
Under Body Measuring Dimensions
Engine Compartment and Front Floor Under View
Middle and Rear Floor Under View
Frame Repair Chart
Top View
Side View
Rust Prevention
Cross Section of Body and Sealants
General
Engine Compartment, Front Wheelhouse, and Damper Housing
Dashboard Upper, Dashboard Lower, and Roof Panel
Front Floor and Rear Floor
Rear Side Outer Panel, and Rear Panel
Under Floor, and Rear Wheelhouse
Soft Chipping Guard Primer Coat
General
Coating Diagram
Rust-preventive Treatments
General
Undercoating Diagram
Area to be Covered by Anti-rust Agents
Materials and Tools
Paints
Body Paint
General
Refinishing Processes
Preprocessing of Painting
Treatment of Metal Surface
Undercoating
Intermediate Coating
Top Coating
3-coat Pearl (White Pearl) Paint
Coating Procedures
Painting Repair (Gradation)
Plastic Parts Paint
Features of Plastic Material
Use of the Repair Material (reference)
Undercoating
Top Coating
Glossary
