Replacement3-1
Roof Panel3-20 |
Roof Panel3-20
Mass Production Body Welding Diagram
3-21
Removal
Roof Panel (cont'd)3-22
Installation
- Set the new roof panel into position and clamp it. Check the body dimensions (see section 4) .
- Install the rear mounting bolts, and tack weld the roof panel.
- Temporarily install the windshield, windshield side trim, roof side trim, door, and tailgate, and check for differences in level and clearance.
Check the operation of the tailgate.
- Do the main welding.
- From inside the vehicle, plug weld the front and rear roof rails.
- Weld the roof panel, rear pillar gutter, and rear inner upper pillar.
- Apply anti-rust agent to the roof carrier brackets and roof rail brackets.
Replacement3-1
Roof Panel3-20 |
